Alternator issues? issue now found ish
Right as ever im after some advice,
Since ive restod my saph ive been having alternator issues, before i used to get 14v at the ecu,
After putting the car back together i noticed this had dropped down to 13.5 i put this down to having painted/powder coating everthing n ruining good earths
but the more i drove the car the more the voltage strated dropping, now reading all the horror storries about what low voltages can cause i took action n bought another alternator(second hand but was working fine when taken out of the car)
probblem is this alternator is showing identical issues! even down to producing the same voltage at the ecu,
So before i bite the bullet n buy a new alternator from burton power is there anything else that could be causing this powwer drop??
like break down of wires due to heat from the turbo??
Any suggestions welcome cheers jay
Check the charging circuit, including the contacts on the lamp inside the instrument panel
I had all kinds of electrical gremlins that appeared to be alternator-related, I even swapped alternators as you describe.
This solved my problem
Neil.
Neil.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Jay check the main wire from the alternator to the battery(runs on chassis leg under turbo) as this will probably be green/corroded.
If you have a multimeter check the continuity from the alternator connection to the battery positive terminal.
Cheers rich i was thinking this could be te issue as like a tool ive not been running a heat shield!!
i may re-wire the charge circuit just to be on the safe side?
aka Turbosailorboy
Yeah i just run a new wire direct from alternator to battery. Taped up old wire ends and left in place.
You could run a temporary wire using a 'jump lead' just to check
good thinking with the jump leads as well
cheers
because thats just on idle with out any darin like light/s fans etc, i have seen the voltage drop to 12.5 n the bat light flicker!
also low voltage aint good when hard on boost, the fuel pump dont like it!
have a read of stus articals
http://www.motorsport-developments.c...AF257.tech.pdf
Jesus battery cable, that is so seriously not needed, a 90 amp alt will put out continuously around 40 amps if it's a good one, the 90 is a peak for a split second.
Some much thinner wire such as 56/030 is more than up to it, 76p a metre from
vehiclewiringproducts.co.uk this is thinwall which will be much better with the heat of under bonnets also, this carries 39 amps continuously and is similar to what I've used, I used 2X 28/030.
If you use gold plated terminals on the wire this would be even better.
A 90 Amp alternator will do 80 Amp all day long and will peak at over 100 Amp. It will not deliver 100 Amp for a very long time but an hour won't be problem. I repair alternators and starters for a living so couldn't resist replying.
Very unlikley in the confines and heat of a cossie engine bay being cooked right next to the turbo, bit different to on a test rig in a nice cool workshop, I test all mine at the place where I repair them also, if I'm feeling lazy I let the lads do it.
As you know the more they output the faster they wear my example was based on a average expected use go drawing even 90 from a 90 alt and it aint going to last long, in use I always say ideally for long life alt needs to be around three times capacity that you regularly draw, not to be on limited time.
13.5V is fine but it should not be dropping under 13V under load, the battery light coming on to me would indicate that the alternator can not cope with the draw. I would check the engine earth strap along with additional earth points first and if not the alternator. I assume as you have replaced alternator once, regulator can be ruled out unless you used one from old one and was alternator new or second hand?
Martin
Martin
Thakns for all the helpful replys!!!
well ive just nipped out to the garage n check/rechecked all the earths, All seam fine so moved on to a jump lead direct from the alternater to the battery as suggested by rich!
And problem solved ish ha!!
on idle im getting 14.0v at the ecu!! with lights on 13.7 and lights + fans on 13.4!!
i cant see what happens under load but i think its safe to say that due to me being a twat not running a heat shield had cooked the charge wire!!!!!
I will say though im thinking of haveing the alternator refurbished as well just for the belts and braces approach!!!
chees jay
chees jay
Why ? You know the output is OK with a good wire.
The standard wire is 6.0mm^2 in size if you're going to buy new. This size will be fine, unless you're running with a higher rev limit than standard, in which case slightly bigger would be better.
2 x 28/030 together are rated at 50A, the same as the standard alternator wire.
jonfoc
16
Sep 11, 2018 05:35 PM
