Apex lowering springs???
Any good buying these apex springs off ebay? And is it ok to put em on standard shocks?? What will be best drop 35 or 40mm? Jus want it sitting nicely so no gap between the standard rs wheels n arch.
The gap will depend on what profile tyre you are using. I remember I had mine lowered so there was no gaps in the archs on a 45 profile and that was a 50/60mm drop and the car handled awful and the exhaust bottomed out all the time. I hated it.
Never had apex springs. So i'm afraid I can't shed any light on them.
The only springs I know to avoid like the plague is Gmax. Cheap nasty, back springs sag after a few hundred miles.
I have some cobra springs that are 30mm if you are interested as i will be rasing my car up have a look at the sig picture for height!
Morph, how much do you want for the springs?? as i am on spax springs and they are shite too
They are good yes,id use them again mate.Not sure how they were listed as i bought them through a local motor factors and the lad who ordered them said they are -40mm springs for rs turbo.Hope that helps
i may buy some of these instead of the spaxs.
I had apexi and were fine.They were 40Mm drop and sat nice.Should be what you want.But be warned your inner tyres will wear out nice and quick and you find speed bumps your worse nightmare! Im going from experience but must say the handlin was ace.Yeah stay away from spax unless you like snapped springs once a year.
Been running Spax like Joe for 2 years now!
Lucky.As they did a batch of springs were the paint falls off in under a year.Had two sets snap on the front and rust on the back.I was shocked to find out i wasnt alone.Bumped into at least 3 other people with same problem.Lucky enough i weren driving the car both times they snapped.So i dont use them anymore for that reason.
Hi
I have apex springs -40mm on my rs turbo and dont like it... On my xr3i have -60mm, ( I dont recomend for daily use) not apex springs, but is much better...
So i want to change for eibach or cobra springs, -25mm or -30mm, something like this eheh
regards
regards
I have Apex on my Turbo'd Bonus, i love them! They are one of the only combinations of springs/shocks that sit the car nice and level instead of arse in the air. The ride is harsh, but i found no where near as bad as previous Spax/Koni set ups. I have the -60mm options which is -40mm on an RS Turbo. You MUST fit adjustable bottom arms though to bring the camber back in line so that it drives nicely and doesnt scrub the insides of the tyres!
SMILER258
Sep 28, 2015 09:04 AM
Adam Graham
Sep 6, 2015 06:04 AM
