HCS to Endura ?
Old May 24, 2010 | 10:45 PM
fester1117mk1's Avatar
fester1117mk1
Default HCS to Endura ?
Hi all ! First post so please be gentle...
I've got a 94' HCS engined fester thats on it's last legs, Another engine is the only way forward !
Trouble is, HCS engines are hard to find (no, really !) - but endura's are everywhere...
Is it possible to use the endura as a replacement ? I know the compression ratio is higher (9.5-1 instead of the 8.8-1 HCS), as far as i can see that should make little difference as i can't swap the heads (different shape pistons i believe).
I'm guessing the main sticking points would be the inlet manifold and cfi unit.
Any help would be most grateful !
Old May 24, 2010 | 10:48 PM
jonny s2's Avatar
jonny s2
i know someone with an extremely low mileage hcs engine from a bonus, just a shame your so far away
Old May 24, 2010 | 10:55 PM
botters's Avatar
botters
competant bodger
yeah inlets cant be swopped over as the entire hcs inlet wont even cover the ports on an endura! have you considered a 1600 crossflow? this would be an easier swop and the engines are easier to find plus they are a cracking engine unlike the endura!
Old May 24, 2010 | 11:10 PM
fester1117mk1
Ah, you're a dreamer of beautiful dreams...
Trouble is i'll have to disagree, they're even harder to find !
To be honest this is just a nice clean daily runner (you can't mod a 5 door fester - it just isn't right !), it's just not worth spending that much on it.
My engine has basicly worn out the tappets (the ones on top of the camshaft) and the cam itself, it also has started to burn oil - so in an ideal world, all i need is a new bottom end. At £400+ for a recon, you can see why i'm trying all other possibilties first...
Old May 24, 2010 | 11:20 PM
botters's Avatar
botters
competant bodger
last time i looked for a replacement for a mate i ended up buying a whole rotten fiesta with a good engine for £100 off a trader and just swopped the engine over might be the easiest way
Old May 24, 2010 | 11:34 PM
fester1117mk1
To be honest i think you're spot on there... Just didn't want the hassle of having to remove 2 engines (getting lazy in me old age !), but it's probably the best way.
Thanks for your help, much appreciated !
Prickly_buzz
Dec 7, 2017 09:52 PM
base190380
Sep 3, 2015 08:32 PM
Bobby9779
Aug 11, 2015 06:47 PM
FAST FORD
Aug 15, 2007 10:50 AM
Mike Graham
152
Jul 25, 2006 04:34 PM
