No oil pressure?? Help needed quick.
Old May 24, 2010 | 10:08 PM
Daniel Clement rs turbo's Avatar
Exclamation No oil pressure?? Help needed quick.
Hi lads, I've just put a engine into my frst, doesnt seem to hold oil pressure, oil light came on wen I started da car, it said it's about 11psi on da gauge at max and wen I rev it it goes up to 25psi maybe more and the oil light goes off, took the oil feed off the turbo and it just splutered out oil.. I've put a oil cooler kit on too and hav made sure to keep the air locks out.. Does anyone have any tips that will help me find out what the problem is, p.s. It seems to pump oil fine as checked it for that.. Thanks lads..
Last edited by Daniel Clement rs turbo; May 24, 2010 at 10:22 PM. Reason: Bad spelling lol
Old May 25, 2010 | 07:23 PM
Need help lads because no one has a clue what's going on.. Do you think I might need to upgrade the oil pump to cope with the oil coolers large pipes..
Old May 25, 2010 | 07:57 PM
LHD220Turbo's Avatar
LHD220Turbo
has the engine had a rebuild recently? is it a new pump or old?
it could be a number of things; the strainer could be clogged, as could the pick up pipe.
Old May 25, 2010 | 08:07 PM
No wasn't a rebuild just a 2nd engine put in while the old one gets a overhaul, I'd say the pump is old.. It's my everyday car so need it sorted otherwise noting get done on the old one.. What else could it be.. The engine ran fine b4 hand as far as I know..
Chas
Sep 21, 2015 08:57 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
