Turbo help
Old May 21, 2010 | 08:16 PM
conor.rst's Avatar
conor.rst
Default Turbo help
looking for a new turbo for my s2 and i just want to know the difference between the 3 turbos below.
I am aiming to reach 250 bhp in the not so far away future so i need a turbo that will be capable of this
so what are the difference between theses:
2wd cossy t3 -
4x4 cossy t3 -
stage 3 t3 -
Also what kind of power are they capable or running.
Old May 21, 2010 | 11:00 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I think but i'm not 100% on the Cossie ones that 2wd is .36/55 good for 230bhp, 4wd is .48/55 as is Stage 3 T3 and good for 280bhp.
But as I said i'm not 100% on the cossie ones, sure someone will know though!
Old May 21, 2010 | 11:07 PM
conor.rst's Avatar
conor.rst
Yeah mainly i wanted to know th difference between a 4x4 and a stage 3 t3 i thaught they where the same ?
Old May 22, 2010 | 08:51 PM
conor.rst's Avatar
conor.rst
also dose the cossy t3s fit as a direct replacement.
Old May 23, 2010 | 05:47 PM
EssexMikeSi's Avatar
EssexMikeSi
You have to also remember that in 'real world' driving, is not always good to have a huge turbo as they'll be laggy and before its fully boosted up and your getting its full potential you'll be at the next bend in the road and having to back off, and that n/a engined little pug 206 gti 180 (good example of a light nippy n/a engined car) will be well away leaving you behind.
Old May 23, 2010 | 07:14 PM
conor.rst's Avatar
conor.rst
No pugs gunna be leaving me behind when the antilags on
Old May 23, 2010 | 07:34 PM
white2lsr's Avatar
white2lsr
Just fit a .48 exhaust housing to your T3. It will make it a little bit laggy but should help flow further up the rev range.
Old May 23, 2010 | 07:35 PM
rsmark86's Avatar
rsmark86
to run the cossie turbo you will need to make a down pipe ... im running a stage3 t3 and am aiming for the same power mate ...... and as for them shitty little pugs you wouldnt even bother as you will be out chasing cossies and scoobys with a true 250bhp
Old May 23, 2010 | 07:37 PM
EssexMikeSi
When iused apug as a example i had in mind the sort of area i live in which is country roads with alot of bends and not many long straights. Obviously on a dual carriageway you'll leave them behind.
Old May 23, 2010 | 07:59 PM
conor.rst's Avatar
conor.rst
Scrap that.
So to fit a cossy 4x4 turbo i need a down pipe made ? apart from that it all fits straight on ?
Old May 23, 2010 | 08:14 PM
LukeDaisley's Avatar
LukeDaisley
is your standard turbo still working/ for sale?
Old May 23, 2010 | 08:16 PM
conor.rst's Avatar
conor.rst
Yes it is perfect and has no play at all i even still have the recipe from turbo tecnics from when it was refurbed not done many miles since.
Old May 23, 2010 | 08:39 PM
conor.rst's Avatar
conor.rst
Somone must know ??? do i only have to have adown pipe made to make a cossy 4x4 tubo fit
Theres one on ebay that im gunna nab so i need to know.
Old May 23, 2010 | 09:01 PM
project rs's Avatar
project rs
heres mine
Old May 23, 2010 | 10:07 PM
jonny s2's Avatar
jonny s2
i would just use a stage 3 t3 direct fit and more than enough for the 250hp
for the cossie turbo there would be some messing involved, but it has been done
Old May 23, 2010 | 10:26 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
close, the 4wd cossie one has a trim of 60, but spot on otherwise.
i use a 4wd cossie one on a 0.48 exhaust housing and pulls nicely.
Old May 23, 2010 | 11:19 PM
conor.rst's Avatar
conor.rst
Thats what im thinking
Old May 26, 2010 | 09:44 PM
JohnnyBgood's Avatar
JohnnyBgood
Virgin, Its true!!
So can you fit a 2wd t3 if you use the standard ERST exhuast housing and elbow?
Or does the blades foul the housing....
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
