4x4 saph cosworth running prob
Old May 20, 2010 | 10:08 PM
rs nuts's Avatar
rs nuts
Default 4x4 saph cosworth running prob
been too work on a car for a mate of mine , and cant figure why the car when running is not burning the fuel in bore 2 +3 even though there is a good spark on all 4
the lad has changed 4 plugs, new rotar arm , dizzy cap , phase sensor ,crank position sensor , new water temp sensor
strange one for me , compression is fine on all 4 aswell
any help much appreciated
Old May 20, 2010 | 10:24 PM
ASHCOSSIE's Avatar
ASHCOSSIE
u aint got the injectors plugged in the wrong way round have u mate
Old May 20, 2010 | 11:11 PM
rs nuts's Avatar
rs nuts
they havent been touched , the lad was just driveing it around and then started too run rough
Old May 21, 2010 | 08:24 AM
rog's Avatar
rog
Have you changed the leads? I'd swap them around, put the good leads onto the bad cylinders and vice versa, if that changes things then the leads are duff.
Also if this doesn't work you can check the injectors are getting signal pulse controlled by the ecu, but unlikely to be an issue if some fuel is getting through and 2 of them are definately working, would more than likely effect them all.
Old May 21, 2010 | 11:32 AM
rs nuts's Avatar
rs nuts
ok worth a try , deffo getting fuel plugs are pisswet in fuel, but its getting a strong spark on all 4 leads, puzzleing me
Old May 21, 2010 | 03:37 PM
martysmartie's Avatar
martysmartie
Sounds as it's overfueling as with most his gone in head first replacing all sensors to no avail, check the MAP sensor hose is in good condition and not cracked and that the phase sensor wires have not corroded and shorted, also check the injectors are pulsing correctly. The most unlikely thing is that the earths for the injectors have shorted but think you would notice this as injectors would run all the time.
Martin
Old May 21, 2010 | 11:51 PM
rscos2004's Avatar
rscos2004
Default cosworth running problems.
Have you checked the co as mine is running 10% at the minute and eating plugs thats what this maybe doing they just dont run.
jason_nike
Aug 18, 2019 10:53 AM
c20tbo
Aug 17, 2015 10:19 PM
Aug 14, 2015 07:29 AM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
