HELP!!! xr3i efi running rough
Old May 19, 2010 | 10:39 AM
tony perth's Avatar
tony perth
Default HELP!!! xr3i efi running rough
Hi there i have a 90 xr3i efi which is hard to start and struggles to idle.
All vaccum pipes checked with no leaks apparent. apart from the pipe that goes from the air intake halfway over the cam cover where does it go?
any ideas would be great.
Tony.,.,
Old May 19, 2010 | 05:00 PM
If you mean the main feed pipe to the throttle body is leaking this will defo cause issues, and is very common problem, as is the fuel enrichement relay located in the kickpanel, a lot disconnect this as it richens the mix way too much, causing bad starting on some.
Old May 19, 2010 | 11:01 PM
tony perth's Avatar
tony perth
thanks i,ll give it a go and get back to you!!
xrmalin
Sep 13, 2015 06:52 PM
RSmark84
Sep 13, 2015 01:29 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
bigryrs
Sep 7, 2015 06:45 PM
