Amal Valve RST/Cosworth?
From: Dewsbury, The parts were they don't abduct their own children!
Hi Everyone,
How do I tell if an Amal Valve is for a Cosworth or an RS Turbo?
I have a box with a few different ones that I have accumulated over the years and would like to sort them out.
From memory there are a few that have a light brown plastic cover and the others are dark brown.
Darren
Darren
Black with 3 outlets is cossie
Brown with 3 outlets is erst
black with two outlets is frst or small turbo escos but more than likely a fiesta RST one.
Also come on a load of other cars not just fords
thanks
I would imagine that when running Cosworth Management that you would require an Cosworth Amal Valve? Or would it depend on the MAP/Set-Up?
Mr Joe - I'll get them sorted this week and let you know.
There is no difference between the cosworth and escort amal valve apart from colour. The jets inside the amal valve should be set per engine spec and tune.
The FRST / ST Escos electronic solenoid valve is not the same as the Amal valve above. Made by different companys to work in two different ways.
