anyone know what this is?
Old May 16, 2010 | 10:02 PM
box360's Avatar
box360
Question anyone know what this is?
hello im new
I found this plug hiding under a plastic cover on my st170 is it supposed to be connected to something? it looks like it has been tie wrapped out of the way, the car runs fine with no problems, any ideas?
Old May 17, 2010 | 01:21 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
Don't know what it is or what its for but on my old one it was loose as yours is and all was fine, think its some redundant sensor wiring used on another model.
Old May 17, 2010 | 06:16 PM
focusv8's Avatar
focusv8
Looks like a water temperature sensor.
Radiator fan run on switch if the cables are Red and Green with Yellow.
Old May 17, 2010 | 06:46 PM
MisiekT_PL's Avatar
MisiekT_PL
temperature sensor AFAIK
Old May 17, 2010 | 08:45 PM
sir nose's Avatar
sir nose
air temp sensor
Old May 17, 2010 | 08:46 PM
box360's Avatar
box360
thanks guys, do you think it's supposed to be connected?
Old May 17, 2010 | 08:48 PM
turboRS's Avatar
turboRS
C16OSY
thats standard mate. its an outside air temp sensor. thats exactly where it belongs!!!!
Old May 20, 2010 | 09:02 PM
RichieST's Avatar
RichieST
Its not the outside air temp sensor as thats behind the bumper, it's the under bonnet air temp sensor. If it gets a bit toasty under there then the fans will cut in to help prevent heat soak!
