T5 bolt size
Hi guys, I need to know what size the bolts are in the rear mounting, the little one that bolts to the bottom of the box and then sits in the rubber bush on the X member.
also can you tell me please what the clutch arm pivits on ? is it a bolt or a propper pivit. thanks Paul W.
DavidK
Sep 27, 2015 02:55 PM
