bosch 044 fuel pump
Old May 10, 2010 | 02:21 PM
Phil2002's Avatar
Phil2002
Default bosch 044 fuel pump
What power should you change your standard fuel pump to a 044 i'm stage 3 at the mo on a standard re wired pump should i upgrade it???
cheers,
Phil
Old May 10, 2010 | 02:23 PM
james kiely's Avatar
james kiely
from 300bhp i would change to 044 phil
Old May 10, 2010 | 02:26 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If its a 20 year old pump then its worth changing at standard power IMHO!
Old May 10, 2010 | 02:55 PM
Phil2002's Avatar
Phil2002
my tank sender is fucked so was gonna change the whole lot while i was there tank sender, tank, pump, filter just wasn't sure wether to upgrade the fuel pump to a 044 or not.
Old May 10, 2010 | 03:01 PM
Chip's Avatar
Chip
For the few quid extra versus a replacement standard one, you may as well.
But a new standard one correctly wired in should cope with stage 3.
Old May 10, 2010 | 03:26 PM
RS500/364's Avatar
RS500/364
Think of £50 put a new pump on same type
or £110 for the 044 with the fuel system under more pressure since changing mine feels more repository and seems to use bit less fn why
Old May 10, 2010 | 03:42 PM
Phil2002's Avatar
Phil2002
Thanks for the replies think i'll go for the 044 as the money is not a lot different and at a later date might go t38 and a set of black seimens!
Thanks again
Phil
Old May 10, 2010 | 03:50 PM
Chip's Avatar
Chip
Definately a good plan if you are looking at 400+ soon anyway
Old May 10, 2010 | 05:39 PM
The 044 pump is very little extra flow, the main differnce is it does have a much higher lockout pressure, flow is around 375L/hr on 941 and 400L/hr on 044.
Old May 10, 2010 | 06:48 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
where did you get your figures from?
the ones i got told from a bosch dealer was a 941 gives 150L/Hr and a 044 gives 200Lt/Hr, there is an in between pump, 979 @165Lt/Hr.
Old May 11, 2010 | 06:28 PM
I got the figures from a actual in use/under load test for the 044, sat in front of me, shows output, current, pressure, I remembered the 941 pressure.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
