Looms
Old Jan 14, 2005 | 08:34 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Default Looms
will a 4x4 loom fit a 2wd saphy?
James
Old Jan 15, 2005 | 12:04 PM
RSCosworth's Avatar
RSCosworth
why do you want to change it?
Old Jan 15, 2005 | 12:09 PM
RSCosworth's Avatar
RSCosworth
I think there is something with the idle speed control valve that is different on 4x4's. (you're talking about cossy's right?)
Old Jan 15, 2005 | 02:35 PM
svony's Avatar
svony
I did a search on this recently... the map sensor wires need to be swtiched around (forgot how exactly), dont remember what else but it's pretty straight forward.
Old Jan 15, 2005 | 03:16 PM
Johnny Boy's Avatar
Johnny Boy
Default Re: Looms
James
Hi Jim, i have worked At Ford Motorsport Boreham and Pectel for over 12 years! Manufactured all of the works engine looms personally to mod spec with the highest grade materials! There are certain things that need changing. The TPS wiring needs altering and the power up on the chassis split is different! If you need assistance i can help you if you send both harnesses to my Company, Motorsport wiring Solutions! I can check the 4x4 recondition and get it so you'll be able to plug straight in! Regards John
Old Jan 15, 2005 | 08:05 PM
bigjim172000
Cheers for the replys everyone but i think im going to pass on modifying it!
Thanks again
James
Old Jan 15, 2005 | 10:49 PM
dark3drcos.kickass's Avatar
dark3drcos.kickass
what is this about the power up on chasis split as i run level 8 with 2wd loom and don't know what this means
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
muz
Sep 30, 2015 08:29 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
