fiesta mk1 zetec
Old May 7, 2010 | 03:37 PM
1cosworth's Avatar
1cosworth
Default fiesta mk1 zetec
hallo forders ,can someone tell me if i can fit a2lt zetec to a mk1 fiesta including the gearbox?is it going to be a straight swap technique?
Old May 7, 2010 | 06:11 PM
bythomson's Avatar
bythomson
zetecinside.com, and short answer no. not straight forward but not impossible.
firstly you need to cut inner wing to make room for 5 speed gearbox, and same at other end to make room for length of engine. new engine mount welded in, new fuel system, new loom and ecu, mk1 xr2 geabox cradle and driveshafts
Old May 7, 2010 | 06:18 PM
el sumpy's Avatar
el sumpy
wej racing !!! =D
hello iv just put a rs1800 zetec in my mk1 and still using the 5 speed ib5 you need to cut out the inner arches . iv used the front engine mount on mine witch is preaty easy to do but yes its a easy transfer
https://passionford.com/forum/restor...le-bodies.html there my thread
Old May 7, 2010 | 07:25 PM
zetecdan's Avatar
zetecdan
looky here http://www.zetecinside.com/xr2/stepbystep.shtml
and here http://xrtwo.speedcentral.co.uk/viewtopic.php?t=60072
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
TPM961
Jan 15, 2018 10:50 AM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
BRAM
Sep 8, 2015 07:11 AM
Ben26
Sep 3, 2015 07:55 PM
