4x4 rear shocks
Old May 5, 2010 | 01:21 PM
David XR4x4's Avatar
David XR4x4
Default 4x4 rear shocks
can anyone tell me if the rear springs and shocks off a cosworth 4x4 will fit onto my XR4x4? if they do will it be a straight swap? cheers
Old May 5, 2010 | 02:34 PM
martysmartie's Avatar
martysmartie
Almost certain they will, you can not however use 4WD shocks on 2WD as there thicker but as you have 4WD think it will be ok.
Martin
Old May 5, 2010 | 02:51 PM
David XR4x4
ok thanks for that bud
Old May 8, 2010 | 01:44 PM
Yes and yes, the 4wd shocks can be used on 2wd by cutting 1/4" of each end of the bottom eye fitting, conversely 2wd can be sued on 4wd with spacers(washers) to take up gap.
FlashRS
Sep 14, 2015 12:36 PM
3drRich
Sep 13, 2015 07:32 PM
mint_s2
Sep 2, 2015 08:58 AM
dal3door
Aug 13, 2015 06:55 AM
