1.8 xr2i clutch
my clutch has started slipping so im going to change it this weekend and wondered if any1 could throw me a quick guide together to do it?
my mate who is helping me has only done cable clutches before never a hydraulic.
im buying a clutch kit and a slave cylinder. so all will be changed at once.
i might be wrong as i have since been informed of this.
im running it in a mk5 fiesta and just assumed it was hydraulic but been informed by my local motor factors im wrong too.
although i am using an ib5 gearbox if this makes any difference?
easiest way is to have a look at the top of the box and see if a cable is present , you might have a hydraulic clutch in it , but you said 1.8 xr2i , so I guess it is a mix match then
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
