Head experts update block help
Formerly know as Puss
Ok chaps ive been having a tidy up in the garage and found this head i forgot i had
Could anyone identify cam ect cheers
Yup as above Piper 285T2 and yes the 285T is the better cam IMO too, not as laggy as the T2, port work doesnt look great TBH the guides have not been flushed to the port walls which is essential for increasing flow and from what I can see very little has been done to the exhaust side, looks like standard valve sizes but inlets look SS maybe?
Take a peek at this thread for plenty of pics of head work! https://passionford.com/forum/ford-e...strictive.html
Cheers guys i got it with a block aswell will get some pics when i pick it up from my mums.
So in general its worth keeping as a spare? From memory the chap i got it from said it had just had a new cam and valves.
Its true Dave i can move again
Ok chaps ive now got the block at mine and took some pics any info you could help me with would be great
Looks like its got ARP bolts and Accralite pistons they have 1138xc81 and 12274 on the bottom of them not got a clue about the rest pics below
I thought that, but if you look closely its the same, like karlos said the inlet valves look like stainless items, they also look bigger (like Christian said), and anyway i dont think you can get stainless valves in the origional size? The head also doesn't have bronze valve guides which i would expect it to have if it was ported by a known company, saying that though the general inlet port shape (compared with pictures of decent heads etc) don't look too bad.....
Rob,
Rob,
It does look different but its just the crap on it.
Rob,
Rob,
Not sure on standard valve sizes, i can have a measure tomorrow for you, have you got any vernier calipers?
Also i don't think you are measuring the true diameter, your tape measure needs to move up a bit
so you could have 43mm valves.......
Rob,
Rob,
Not got any vernier calipers will check the measurements again tomorrow to make sure
