Series 2 copper brake lines - does anywhere do a kit ?
Old May 1, 2010 | 09:08 PM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Default Series 2 copper brake lines - does anywhere do a kit ?
I know I can make my own up but a while back I remember somewhere selling a full kit of ready made brake lines for the whole car (not braided hoses but copper lines)
Does anyone know if anyone sells a brake line kit ready made and shaped ready to fit straight to the car or am I stuck with having to make up my own ?
Old May 1, 2010 | 09:22 PM
Bryan_RST's Avatar
Bryan_RST
i think burton power sells them
Old May 1, 2010 | 09:24 PM
project rs's Avatar
project rs
demon tweeks do them too
Old May 1, 2010 | 09:34 PM
H7 CYA's Avatar
H7 CYA
probably alot cheaper to get some from a motor factors and shape them yourself tbh.
Old May 4, 2010 | 08:43 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
why bother just buy std ford lines off another car, If you wanna do it properly fit non abs lines and compensators.
Old May 4, 2010 | 08:45 AM
RSandy's Avatar
RSandy
u can redo the whole car in braided and remove the abs system for not much more than 1 of them so called ready made copper line kits!
thats the way iv gone anyways
Old May 4, 2010 | 08:52 AM
diamondrst's Avatar
diamondrst
Where did u get the braided set from or did u do it yourself and is it from the master cylinder??
Old May 4, 2010 | 10:06 AM
RSandy's Avatar
RSandy
i just went james listers n bought about 10m of -3 braided line, a couple of t-pieces, a couple of 90degree fittings for the master cylinder, then any other fittings to suit ur caliper/drum set up n flexi joins. i spent a bit more on extra fittings for my bias valve set up
all the fittings are the reuseable type, so can all be fitted up at home easily
Old May 4, 2010 | 03:22 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
as rsandy said braided all the way, saves kinking the pipes in the future and piss easy to fit, im doing it with my track escort and running the brake and fuel lines inside the car
Old May 4, 2010 | 04:29 PM
RSandy's Avatar
RSandy
dont forget if u runnin fuel lines inside, pay the little extra and get the teflon lined fuel hose, stops it stinkin of fuel! i also have a whole reel of -6 fuel hose suitable for this if u need any
Old May 4, 2010 | 07:29 PM
gingerturbo
cheers for the offer my m8's got some teflon lines left over from his scoobie not sure how much though, have ya got any fittings left over
Old May 4, 2010 | 08:16 PM
RSandy's Avatar
RSandy
no fittings, just a reel of new goodridge -6 teflon lined hose. offer is there if u find u need any tho
Old May 4, 2010 | 09:14 PM
stuartrsturbo's Avatar
stuartrsturbo
how much did that all cost if you dont mind me asking?
Old May 7, 2010 | 08:54 PM
s2turbsZVH's Avatar
s2turbsZVH
Bump
Old May 9, 2010 | 07:45 PM
RSandy's Avatar
RSandy
think i paid £150ish total, but u cud instantly knock 20quid off that as i had to buy 2 extra 90degree fittings to fit my bias valve set up
just assume the -3 hose is going to be roughly 6-10quid per meter, and then fittings 10-15 quid each for the reuseable type
will try and find my receipt to get exact amounts, but hopefully thats enough info to go off anyways
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
yatta
May 21, 2016 10:31 PM
Billy_RS
Sep 13, 2015 04:17 PM
hopper350
Sep 4, 2015 12:53 AM
