02 mondeo tdci fuel pump fault
Old Apr 28, 2010 | 02:24 PM
sdk72's Avatar
sdk72
Unhappy 02 mondeo tdci fuel pump fault
Hi all,
I bought a tdci mondeo last month and all was fine, until last week when 2 mins into my journey the engine judderred like it ran out of fuel, cut out & died. It won't start again. I have had it started with easy start (apologies) but thats it. I have followed threads on here and replaced the cam sensor. no joy. had diagnostics done - £70 later: faults were fuel pump and injectors. replaced pump near fuel tank - nothing. would the faulty pump be reason the car won't start (one on engine) - as am worried about throwing money at it blindly. any thoughts or help greatly appreciated.
also I dont have the remote fob. can this effect the immobiliser coming into play as I have replaced the battery and getting nothing from master key??
yours confused
cheers
steve
Old Apr 28, 2010 | 02:29 PM
R4N SS's Avatar
R4N SS
sounds like the pump in the engine steve - a fiesta i bought did the same after a week of buying it.
Pm me as i have a great contact who can sort it out cheaply and they do mail order to
Old Apr 28, 2010 | 03:19 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
What fault codes came up?
A fuel pump is VERY expensive (no change from £600) so you don't want to be swapping it if it's not the culprit.
Old Apr 28, 2010 | 04:17 PM
sdk72's Avatar
sdk72
eee. dunno. the lad who took it away just said pump errors and looking at £600 plus labour.
Old Apr 28, 2010 | 06:54 PM
DanW@FastFord
Spelling Club King!
Ask him if he will guarentee that will fix it. If not, don't do it.
Often when the pump goes it breaks up and tiny fragments block up the lines and filter, they need to be looked at too.
Old Apr 28, 2010 | 07:01 PM
R4N SS's Avatar
R4N SS
you wil need to interrogate the pump properly using specific pump diagnostic software which the normal readers dont pick up on. This will then tell you exactly what is wrong with the pump.
As in the pm, give Owen a ring
Old Apr 28, 2010 | 10:30 PM
DazC's Avatar
DazC
ran, that is for a tddi engine. a tdci has no electronics on the pump. there is a solenoid valve and a pressure sensor only. need to know more about the fault code and the terminoligy that came out of it to make an informed reply
Old Apr 29, 2010 | 08:29 AM
sdk72's Avatar
sdk72
he wouldn't guarantee it, as said injectors might be blocked to. then cost will spiral. will relook at getting diag done again. properly. cheers all
Old Apr 29, 2010 | 12:05 PM
DanW@FastFord
Spelling Club King!
The problem is that the diagnostic check throws up fault codes, but don't actually tell you what's faulty.
As an example - mine is saying I've got a MAF fault, yet even when I swapped it for a fully functionning MAF from a different Mondeo the fault is still there. The fault codes sometimes narrow down your search, and at other times send you in the completely different direction.
My advice would be to speak to a few local diesel specialists, and see if any of them have a suggestion - The very last thing I would be doing is shelling out getting on for £1500 for a new pump/injectors/rail etc unless I was 100% convinced.
Old Apr 29, 2010 | 12:35 PM
MarkyMark's Avatar
MarkyMark
each injector is 200plus from fords and as stated the pump isnt cheap either, it is a very common fault on the tdci's, at my old spares place they were our best selling engine (engine pump and injectors complete)
Old Apr 29, 2010 | 12:37 PM
R4N SS's Avatar
R4N SS
what does a w reg fiesta td have as that is what i had at the time - i pretty sure the guy changed the sensor first which fixed it for 2 weeks and then had to take it back.
I had my pump changed for just under 500 quid all in - was getting quotes from 800 upto 1200
Old Apr 29, 2010 | 12:46 PM
DanW@FastFord
Spelling Club King!
They go for around 155-135 recon, which is a but more reasonable. Still bloody expensive though.
Very different set up, as the TDCI is common rail, and the TDDI is direct injection.
Old Apr 29, 2010 | 12:50 PM
MarkyMark's Avatar
MarkyMark
also there are two types of injectors, if you go down the route of getting injectors make sure you match up by part number,
indeed, 04 onwards iirc is tdci engines, pre 04 is tddi with a totally different injection system
Old Apr 29, 2010 | 01:02 PM
sdk72's Avatar
sdk72
is it not worth getting a new / 2nd hand engine with pump & injectors then? if its £1500 to replace pump and injectors with labour????
Old Apr 29, 2010 | 01:04 PM
DanW@FastFord
Spelling Club King!
You can get pre 04 TDCIs
Old Apr 29, 2010 | 01:05 PM
DanW@FastFord
Spelling Club King!
Most breakers sell them seperately for that very reason.
What exactly is the fault with your car. Is it just not starting, or are their other symptoms? Glow Plug light... smoke.. excessive noise etc??
Old Apr 29, 2010 | 01:08 PM
MarkyMark's Avatar
MarkyMark
yes and no, it depends where you get it from iam going to be honest here and say most spares places cant 100% gurantee a engine, as they dont know the history of the engine before they brake the car for spares, and the last thing you want to do is pay for fitting a crap engine, whether you can get your money back on the engine or not,
is yours a 115bhp or 130bhp engine?, there are quite a few late 05 06 ones knocking about for breaking but i also doubt you will get a honest answer about the milage, being a popular taxi and rep car
i suppose it depends on how long you want to keep the car, if its a long time then get new or recon parts, as least then you know it will last (thats assuming the rest of the engine is in good working order and will last as long as the new pump/injectors ha)
its swings and roundabouts mate,
Old Apr 29, 2010 | 01:09 PM
sdk72's Avatar
sdk72
mine an 02 tdci. cut out. won't start. done 160000 miles. not sure its worth throwing 1500 quid at it
Old Apr 29, 2010 | 01:11 PM
MarkyMark's Avatar
MarkyMark
got to agree with that mate, is it still on orginal turbo?
Old Apr 29, 2010 | 01:12 PM
sdk72's Avatar
sdk72
i have no idea pal. more costs there too
Old Apr 29, 2010 | 01:18 PM
MarkyMark's Avatar
MarkyMark
considering i have a 02 plate mondeo tdci outside my house i keep meaning to put a pas pump on i should have remembered ha, iam getting old
Old Apr 29, 2010 | 01:21 PM
R4N SS's Avatar
R4N SS
well my old fiesta is up for sale if you want it for a couple of hundred quid as the turbo has gone - the rest of the engine runs sweet.
or better still get in the car, drive/tow it down the road and then call the AA/RAC to take you to where i stated in the PM they will then tell you exactly what is up with that car
Old Apr 29, 2010 | 01:25 PM
sdk72's Avatar
sdk72
if it wasn't a 4 hour drive without a trailer. i would pal. thinking my options are pretty pants right now. shame, as when it did run was a nice smooth drive
Old Apr 29, 2010 | 01:29 PM
R4N SS's Avatar
R4N SS
have you rang Owen?
Can you get the pump off yourself and send it to him?
It was a mission of a drive for me (near Heathrow), especially with the car cutting out every 5-10 mins
Old Apr 29, 2010 | 01:31 PM
sdk72's Avatar
sdk72
not rung him yet as of yet as I can't see me making that journey with work and what have you. will get pump off first then prob give him a call although I don't know what i'm looking at
Old Apr 29, 2010 | 01:36 PM
DanW@FastFord
Spelling Club King!
I don't think it's necessarily the pump/injectors though - They don't just stop working, you're more likely to have it cutting out and glow plug light on for a few weeks (or even months/years) before they die totally.
Find out the fault codes, and tell us what they are!
Old Apr 29, 2010 | 01:42 PM
sdk72's Avatar
sdk72
glow plug light came on a couple of times. as did the orange snowflake looking thing air con maybe. anyway - not often and not for long. it just died and that was that. like it ran out of fuel, then everything shut down and was like a tank to roll into layby
Old Apr 29, 2010 | 01:43 PM
R4N SS's Avatar
R4N SS
do the fault codes point at the pump?
If so then i would call him first before you doing anything mate - he wont bite.
As its a mondy its common the for injectors to fail Did this just happen?
I have also heard of a few cars needing ECU updates so it could be that too.
Old Apr 29, 2010 | 01:44 PM
sdk72's Avatar
sdk72
have asked the lad for the codes. he just said low fuel pressure
Old Apr 29, 2010 | 02:32 PM
DanW@FastFord
Spelling Club King!
That would just cause poor running, not a complete cut out.
DanW@FastFord
Spelling Club King!
That just means it's below 5 degrees C, so ignore that one!
Old Apr 29, 2010 | 02:54 PM
sdk72's Avatar
sdk72
one other thing i noted was the mpg got progressively worse prior to its demise. if this makes any difference or not???
Old Apr 29, 2010 | 03:30 PM
R4N SS's Avatar
R4N SS
get the fault codes and put em on here
Old Apr 29, 2010 | 03:39 PM
DanW@FastFord
Spelling Club King!
If you paid him money to diagnose it, then he shouldn't have a problem giving you the actual codes!
Old Apr 29, 2010 | 04:08 PM
R4N SS's Avatar
R4N SS
agreed - i would have asked him point blank to give you the codes, especialyl if you paid him
Old Apr 29, 2010 | 04:12 PM
sdk72's Avatar
sdk72
you'd hope not. still waiting for them !
Old Apr 29, 2010 | 04:14 PM
sdk72's Avatar
sdk72
I didnt know how important codes were till i got on here. too late was the cry.
we'll see what he comes back with . . . . . . .
Old Apr 29, 2010 | 04:20 PM
wobbles's Avatar
wobbles
Did the car start with a jump start? Just had a problem with my mums st tdci mondeo where it was perfect, went into start it, it went then would cut out straight away. Jumped it and it ran again. The next day the same happened. Turned out it was the agr valve. Not sure if all tdci's are all the same set up though. I believe you can blank them off.
Old Apr 29, 2010 | 04:29 PM
sdk72's Avatar
sdk72
it would try and turn over but never fired up. battery so weak it doesn't do that anymore
Old Apr 29, 2010 | 06:31 PM
wobbles's Avatar
wobbles
Thats exactly what i found. Try and jump it and see if it starts. If it does there is a chance it could be this. you can blank it off, or i was about 130 quid for a new one.
