low boost
Old Apr 25, 2010 | 09:11 PM
Juan's Avatar
Juan
Default low boost
Hi,
i have a problem in a friend's car. It's a Cosworth 3dr with exhaust manifold and turbo of a 4x4.
The turbo can not peak more than 19 psi and holds 13,5 psi.
the turbo it's a new turbo technics s113 with a 360º bearing. I don't see any air leaks.
the car has not the amal valve, it has an air leak in the wastegate to setup the pressure
can be a problem with the new turbo??
Old Apr 25, 2010 | 09:24 PM
LHD220Turbo's Avatar
LHD220Turbo
as the turbo is new, it seems unlikely that the turbo is faulty.
i have seen a problem with the waste gate penny not sealing correctly, which causes boost leak
Old Apr 25, 2010 | 09:49 PM
fatmike's Avatar
fatmike
check all vacuum lines for splits and make sure dump valve is not faulty. Is it a new actuator on turbo??? As old ones can play up.
Do you mean the boost is set up on a bleed valve???
Old Apr 25, 2010 | 09:57 PM
Juan's Avatar
Juan
i think too in a problem on the waste gate penny
Old Apr 25, 2010 | 09:58 PM
Juan's Avatar
Juan
the actuator is new. Yes, i think that it's the correct name, a bleed valve.
Old Apr 25, 2010 | 10:09 PM
COLEYST200's Avatar
COLEYST200
is the actuator set at standerd
Old Apr 25, 2010 | 10:13 PM
Juan's Avatar
Juan
Yes, and i had test with another new one, with the same result.
Old Apr 25, 2010 | 10:20 PM
COLEYST200's Avatar
COLEYST200
so have you not ajusted the actuator to give it more boost
Old Apr 25, 2010 | 10:32 PM
Juan's Avatar
Juan
this pressure it's with the actuator tightened to the max.
with the normal adjust, it peak at 16 psi
Old Apr 25, 2010 | 10:34 PM
fatmike's Avatar
fatmike
Basicallly there is no need to adjust your actuator if you have a bleed valve. You do all the adjustments on the bleed valve. I can't remember exactly which way it is now as I dont use one anymore, but winding the bleed valve in or out will adjust the boost either higher or lower. Try adjusting the bleed valve to see if you can get the boost higher.
Old Apr 25, 2010 | 10:57 PM
Juan's Avatar
Juan
I adjust the bleed valve to have the higher boost, and peaks at 19 psi, no more.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Tank Mike
Sep 26, 2015 08:07 AM
