brown gunk in turbo pipe
Old Apr 24, 2010 | 05:04 PM
-DEG-'s Avatar
-DEG-
Default brown gunk in turbo pipe
hi all bought a new samco hose for between the turbo and when i took the old one off loads of light brown gunk came out its mainly coming from the metering unit but a little has worked up to the turbo. What causes this?
Old Apr 24, 2010 | 05:09 PM
StephenC's Avatar
StephenC
..BS Motorsport..
oil vapour returning to metering head via standard breather if your still running it. Most replace breather with baileys oil seperator and vent to atmosphere then block up the existing inlet on the metering unit.
Old Apr 24, 2010 | 06:53 PM
-DEG-'s Avatar
-DEG-
Aint a clue what its running pal not had it long. where is the breather and whats it look like? is it bad to have all that gunk?
Old Apr 24, 2010 | 08:11 PM
cj_rst's Avatar
cj_rst
S2 RST
Normal thing to find gunk in there, mine dripped oil out the last time I had the hose off!
Old Apr 24, 2010 | 08:40 PM
StephenC's Avatar
StephenC
..BS Motorsport..
if your running higher than normal boost (7psi+) on the standard breather its a common occurance.
A standard breather would look like this
where an uprated one would look like
shiny tank on right near that blue arrow
get some pics up and we'll be able to tell
Old Apr 24, 2010 | 10:57 PM
-DEG-'s Avatar
-DEG-
yep just got a standard breather then. where best for an uprated one? How much you talking for 1?
Tidy lookin engine!
Old Apr 25, 2010 | 12:43 AM
tasos77's Avatar
tasos77
rs turbo from Greece...
bailey... 130-140q including the fitting kit. You can find and a used in good condition. I bought mine from ebay for 45q and still is as new...
Old Apr 25, 2010 | 09:59 AM
-DEG-'s Avatar
-DEG-
Thanks everyone i on the hunt for one now
If any one has one or has seen one anywhere can you let me know. CHEERS
j.hammond1
30
Oct 31, 2021 05:28 PM
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
AndrewStrang
Sep 1, 2015 11:16 AM
