cd changer question
Old Apr 24, 2010 | 12:56 PM
gavo01's Avatar
gavo01
Default cd changer question
just gone back 2 the standerd cd player in the focus and it wont play copied cds. sum1 said if i get a changer it will play them so just wonderin whats the best and cheapest 1 to go for.
also if i got one where do i put it cuz i need a cable
Old Apr 24, 2010 | 04:17 PM
M1keLR's Avatar
M1keLR
What year/shape focus? what standard HU? is it the 6000 cd?
If so the 6000 will play copies but not mp3's. In my mk1, the standard changer is under the passenger seat mounted to the seat facing forwards.
Old Apr 25, 2010 | 09:27 AM
gavo01's Avatar
gavo01
yer sorry it is a 1998 mk1 and a 6000 cd player
i was thinking about either putting it under the seat or where the glove box drops down, putting it above that. almost under the passanger airbag.
do u hink that it is possible??
Old May 1, 2010 | 08:25 AM
gazza61's Avatar
gazza61
what cd's are you using? if you are using cheap ones from asda don't bother have the same problem.Use a good make like verbatim i have no trouble now
Old May 1, 2010 | 09:02 AM
gavo01's Avatar
gavo01
so can you only used coped cd's, not downloaded songs from i-tunes? Even on the expensive cd's ?
Old May 1, 2010 | 09:22 AM
gazza61's Avatar
gazza61
it don't matter where the music comes from, i problem i had was that the cd player did'nt like cheap blank cd's so, i used a branded name e.g. verbatim now the cd player plays the cd without 'cd error' or,does it 'jump' it stopped the problem for me
Old May 1, 2010 | 12:42 PM
gavo01's Avatar
gavo01
ok thanks alot il go and get sum then
cheers
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
