st170 front brakes help
planning of fitting hubs and rest of set up this week to my 1.8 focus, will i need to use the shafts of the st170 or will my exsisting driveshafts fit into the splines on the st170 hubs, cheers
also if i do need to use the st shafts will i be able to split them so i just use the outter shaft for the hub and use my normal shaft from the box and join them up?? if ya get what i mean! cheers
no need to change shafts, they fit perfect.
done it on my 2l which has the mtx75 box and loads have done it on 1.8s and 1.6s.
i warn you now though the hub nuts need torqueing to 316 NM!!!!! i had to buy a new torque wrench to do this job and that still only went upto 300NM so just tweeked it a bit more
