T34 only producing 8psi
Old Jan 13, 2005 | 03:32 PM
skeld's Avatar
skeld
Default T34 only producing 8psi
what the hel is the matter with it?
Old Jan 13, 2005 | 03:34 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
boost leak or knackered actuator prob m8
Old Jan 13, 2005 | 03:47 PM
Stu @ M Developments's Avatar
PassionFords Creator
Maybe nowt.. lol
Old Jan 13, 2005 | 04:00 PM
skeld's Avatar
skeld
its not mine its a m8s but the actuator has been checked.
Old Jan 13, 2005 | 04:54 PM
what makes ya say theres anything wrong with it?
Old Jan 13, 2005 | 04:58 PM
dannyblackpool
Boost Builder
makes me laugh the shit a poor turbo gets feels slow- turbos fault, engine pops- turbos fault,smoking - turbos fault
Ill stick my neck out and say 99% it ISNT the turbo,,, boost leak is most probable fault, has the actuator been set to run more than 8psi?? is it the right actuator?? like stu says wat makes you think summits up??? What has happened????????
Old Jan 13, 2005 | 06:28 PM
Jim Galbally's Avatar
Jim Galbally
does it have ableed valve/amal valve connected up to it? if not and the pipe runs str8 from comp housing you'd expect to see about 8psi on a -31 actuator
Old Jan 14, 2005 | 07:24 AM
skeld's Avatar
skeld
im not sure how its set up, as i said its a m8's. hes had a new -31. the turbo is also new. (new to him, second hand off ebay)
it has been running fine for the last couple of weeks, but now and again it wouldnt come on boost. he took it to a tuning company near us and there verdict was.....the turbo wont produce no more than 8psi.
i havent spoke to my m8 in person about it, just in txt as hes been at work.
the company he took it to havent really got much good feedback but he was deperate to get it sorted quickly
Old Jan 14, 2005 | 07:32 AM
Sticky.'s Avatar
Sticky.
Sounds like a fooked actuator to me. Im sure Danny & Stu will guide you in the right direction to getting it fixed.
Old Jan 14, 2005 | 08:48 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Or, on a more positive note, it might not have any blades on it.
Old Jan 14, 2005 | 11:54 AM
Jim Galbally
or the amal valve wire has popped off and the stupid dumb ass "tuner" doesnt have a fookin clue how boost control works
all speculation mind...
Old Jan 14, 2005 | 12:05 PM
DaveEscos's Avatar
DaveEscos
it might be something as simple as nto enough preload on the actuator?
but arent -31's / -34's a minumum of a bar?
Old Jan 14, 2005 | 09:09 PM
Ginge !'s Avatar
Ginge !
just finding my feet
id say boost leak as when my bosst pipen had poped off i couldn get 8psi with no jubilee clip ( fook knows what the turbo was producing though )
that or the turbo is fooked, not unusual if its been running with a boost leek before and then it decided to go bollox
take it to another tuner as 8psi is not alot for a turbo that size , surely it can flow more air UNLESS ya boost hoses are the size or toilet waste pipes
Old Jan 16, 2005 | 11:46 AM
Jim Galbally
no, only if set correctly
and a -31 is half a bar
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
28
Sep 8, 2015 07:10 PM
