Rebuilt Fiesta turbo 1.6 cvh EFI engine.
Old Apr 19, 2010 | 08:50 AM
James Porter's Avatar
James Porter
Default Rebuilt Fiesta turbo 1.6 cvh EFI engine.
Only selling this as ive found a nice full zetec turbo engine instead. Only covered 1700 miles in total since rebuild & is the original engine in my genuine 60,000 mile FRST.
It was rebuilt by Specialised Engines in September 09 & only done the 1500 miles running in last month, it was set up & made 201bhp @ a bar of boost.
Was only rebuilt as i planned to go for more power & was 100% standard when i got it & run perfect before hand. It was stripped down & found that everything was fine but all bearings were replaced (crank was mint so still on original grind) new rings,core plugs,oil & water pump etc, Had a new stage 3 head done whilst it was there so is massivley ported & polished, 1mm bigger steel valves & a Kent cvh34 cam kit & vernier pulley.
This is still in the car so can be heard running until next weekend, this looks & runs like a brand new engine & pulls very well.
Have receipts for £1600+ for the rebuild & head alone that was without the cam kit & pully, Also has a AP fast road clutch which was also new.
£750.
Also i have a stage 2 t2 built by CR turbos & again is only 1700 miles old but cant find the receipt, perfect working order NEVER puffs abit of smoke, complete on a manifold.
£250.
Full OFAC set-up (got omex going on) Loom,ecu, complete inlet, ALL sensors & coilpack.
£200.
Superchips 195 chip (OFAC) & 4 beige 701's which are only 5-6k old-..............SOLD
£150.
Brand new mongoose exhaust for t2 was fitted when engine went back in has 2.5" pipe with 4" outward rolled tailpipe-Mint.
£175.
New airtec alloy radiator this was fitted a month ago & done 90 miles, but got a large capacity one coming with my new engine.
£140.
Very good series 2 LSD gearbox......£150.
Series 2 front & rear strut braces, front is adjustable & rear is fixed, could do with painting......£50 the pair.
Clean standard interior drivers seat is mint no bolster wear at all & no damage to the piping, only downer is the 2 small fag burns on the base of the passenger seat, back seats & door cards all good.
£130......SOLD
Everything listed is what i dont need anymore, everything is either new within the stated milage or from my mint 60,000 mile car.
Can post anything at your cost too.
James 07545 025 300.
Old Apr 19, 2010 | 01:15 PM
matthart's Avatar
matthart
Will you split the head from the engine? Did the inlet get ported aswell?
Price on the head posted?
Cheers!
Old Apr 19, 2010 | 03:23 PM
James Porter
Cheers!
I'll keep you in mind mate but would like to see if i get any intrest in it complete first.
Thanks.
Old Apr 19, 2010 | 03:48 PM
sjoyce666's Avatar
sjoyce666
How much for the bottom end if you did split the engine ?
Scott
Old Apr 19, 2010 | 05:27 PM
gee1599's Avatar
gee1599
i will have the chip and injectors and interior off you see you saturaday mate
Old Apr 21, 2010 | 07:24 AM
weeman84's Avatar
weeman84
Is this engine still for sale?
Old Apr 21, 2010 | 06:04 PM
James Porter
Yes mate my numbers 07545 025300, Thanks.
Old Apr 28, 2010 | 05:47 PM
James Porter
Few more bits added
JoeyBoyden
Jan 4, 2024 02:36 PM
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
knight19770
Aug 4, 2015 12:36 PM
