cosworth problems
Hello
I am having problems with my sapp 2wd cos
When its could there arnt really any problems but the more heat comes in the engine the bigger the problems are getting
It yust fall down everytime I get on the throttle
If I build up the throttle slowly I can yust bairley get it up my drive way
Its running good idle at 800/900 rpm
Hope someone can give me any advice
Check the silly things like no conenctors etc have come off, esp the coolant temp sensor, map, tps, then check the co when hot, adjusting if necessary to whatever chip your using,
Could be the cts has gone duff, is it belching black soot when revved and sooting the plugs ?
co was verry high last time i have checked it
i have yust changed the plugs to new ones the c71
and the ones that came out of the engine seems to be very black
have tested the plug leds they where fine
changed coil, crank sensor,
i was running stage 3 but changed it back to standard to see if the problem was there
so that was the ecu, injectors and map sensor are standard now
as soon as your want to let the enigne work so you can get the reving up if your standing still but if you want to drive away its yust bluuuuuuu
like its misfiring all over the place or getting to much fuell or air
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
