Ford Puma Discuss the Ford Puma here!
Ford Puma, indicators
Old Apr 17, 2010 | 06:54 PM
sulphur's Avatar
sulphur
Default Ford Puma, indicators
Need help, quickly quick.
The front right indicator stopped working the other day, side and rear were fine as were the other side. So I got a new bulb, fitted it and now none work atall.
Checked all connections in the headlight, the bulb is new, found the fuse had blown so swapped that and now it keep blowing fuses. 3 so far.
Any ideas? Really need this fixed 'cos MOT on monday
Car is a 1999 Puma, 1.4
Old Apr 17, 2010 | 09:51 PM
bythomson's Avatar
bythomson
might be loose wire in the indicator stalk sounds like its earthing somewhere and blowing fuses
Ben26
Aug 27, 2015 08:56 PM
borboyous
Aug 22, 2015 11:17 AM
RIB1122
Aug 12, 2015 08:51 PM
Ben26
Aug 11, 2015 04:19 PM
