flame trap on a fourbie
Old Jan 12, 2005 | 09:05 PM
slowpoke's Avatar
slowpoke
Default flame trap on a fourbie
hows it secured ?????
its doin me tits in now im gonna properly throw a wobbler at it in the morning
matt
Old Jan 12, 2005 | 09:06 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
think its just pushed in
Old Jan 12, 2005 | 09:10 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
just a push fit,metal to metal
Old Jan 12, 2005 | 09:12 PM
Stu @ M Developments's Avatar
PassionFords Creator
What ya fookin about at Matt?
Old Jan 12, 2005 | 09:19 PM
slowpoke's Avatar
slowpoke
pmsl im trying to fit the new oil breather, took the red 2 way thingy off but theres no way that black pipe is gonna budge so the only thing to do is remove the flame trap itself
might try and chop it tommorow but theres other wires nearby so knowing my luck i will chop them too lol
i can move the flame trap by pushing it but it feels very stiff
bastid car
AndyRST's Avatar
AndyRST
whats a flame trap ?
Old Jan 12, 2005 | 09:20 PM
slowpoke's Avatar
slowpoke
funny lookin thing under the inlet suppose ot traps erm flames lol
Old Jan 12, 2005 | 09:21 PM
Ok.
For now, put the red plastic thing BACK ON and use it as an extension piece so you can pipe onto the top of it with your new pipe.
Dont get stressed over small jobs
Old Jan 12, 2005 | 09:23 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
so how does the flame trap come out anyway,lol?
Old Jan 12, 2005 | 09:25 PM
Interference fit.
the more you interfere with it the less it fookin fits usually
Old Jan 12, 2005 | 09:27 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
pmsl,come on how?
Old Jan 12, 2005 | 09:28 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
u canm prise it round with a big bar or screwdriver so the pipe will fit onto it
Old Jan 12, 2005 | 09:31 PM
POPEYE,
pmsl,come on how?
I was being serious..lol
POPEYE's Avatar
POPEYE
FAIRY CAKE
so it pushes in then,lol
Old Jan 12, 2005 | 09:32 PM
slowpoke's Avatar
slowpoke
i cant fit the red thing back on
we erm ............errrrrrrrrrrr
destroyed it pmsl
prize what round andy ?
Old Jan 12, 2005 | 09:34 PM
Rs Gus's Avatar
Rs Gus
the flame trap will prize so u can lign it up for the hose to go on
Old Jan 12, 2005 | 09:43 PM
slowpoke's Avatar
slowpoke
we cant put the hose on yet as the old ford hose is still on and wont come off at all
the one with the 90 bend in it it just will not budge
Old Jan 12, 2005 | 10:01 PM
slowpoke's Avatar
slowpoke
come on everyone help meeeeeeeeeeeee !!!
theres gonna be a fourbie breaking for parts soon lol
Old Jan 12, 2005 | 10:07 PM
RobS's Avatar
RobS
try and get it to turn m8, once it does it should pull out while you turn it.
i now there aint much room so try jacking car up and go from underneath
im sure u can see it better from there. probally just rusted in a bit
Old Jan 12, 2005 | 10:11 PM
slowpoke's Avatar
slowpoke
i can get it to move rob so i presume its turning
will have a go at that in the morning
hope to see you and stretch on friday
Old Jan 12, 2005 | 10:21 PM
Rs Gus's Avatar
Rs Gus
get some long nose vice grips on the job grip the hose and yank it
Old Jan 12, 2005 | 10:25 PM
RobS's Avatar
RobS
try get a pry bar or screwdriver under it, once it starts it'll fly out m8
Old Jan 12, 2005 | 10:42 PM
slowpoke's Avatar
slowpoke
the flame trap ya mean rob ???
andy weve been jumping all over the bloody hose with plyers there is no way its foing to come off
twatting thing lol
how can a car get you sooooooooooooooooooooo mad ????
Old Jan 13, 2005 | 08:30 AM
Blimey Matt....
Let me try and find you a pic to help you out. Its often easier to do when you know what the bit you cant see looks like
Old Jan 13, 2005 | 08:47 AM
Hmm...
The only pictures i have on Photobucket arent going to tell you much, but here they are.....
As you can see, the flametrap spout is quite long and the pipe will have a clip on it also. The bottom of it will also have an oil return pipe going into the sump on yours, so if you want to remove the whole trap, this pipe has to be removed at the sump end first.
I suggest levering at the pipe stub end to rotate the assembly into a better position for access and then removing the clip off your right angled pipe or literally cutting it off. The clip should be just a spring clip so will pull off if your lucky.
Hope this helps Matt.
Old Jan 13, 2005 | 08:56 AM
DaveEscos's Avatar
DaveEscos
you wont get that flame trap off, believe me, ive tried!
if your fitting a breather, just push the breather hose over the spout on the flame trap and jubilee clip it.
but you will need to remove the original hoses and the meule valve (red ball ) first
Old Jan 13, 2005 | 10:02 AM
slowpoke's Avatar
slowpoke
thanks guys weve got the red thing off dave its the black hose coming from the trap were having trouble with
going back out to the car now just got up lol
round 5 ................................ding ding !
matt
Old Jan 13, 2005 | 11:53 AM
St3V3_C's Avatar
St3V3_C
Here's a pic:
I have the hose to my breather on the bit numbered '2'
Oh, and 1A is the cossy one.
Old Jan 13, 2005 | 11:57 AM
3drstretch's Avatar
3drstretch
Steve you have your breather plumbed in wrong then.
Old Jan 13, 2005 | 12:05 PM
St3V3_C's Avatar
St3V3_C
Thanks. It's one of those 'jobs for a rainy day'
Old Jan 13, 2005 | 12:07 PM
3drstretch's Avatar
3drstretch
Get out there now it not THAT cold.
St3V3_C,
Both are Cosy.. 1A is later revision and far more effective as it returns oil to the sump.
3drstretch,
You will find he has probably retained the Ford designed 4x4 systems oil return to sump which is VERY effective, so not a bad error all in all
Old Jan 13, 2005 | 12:10 PM
3drstretch's Avatar
3drstretch
Shut up Stu. Wot do you know.
Old Jan 13, 2005 | 12:18 PM
Slightly less than sweet FA and lovin it
Old Jan 13, 2005 | 04:46 PM
CosKev3's Avatar
CosKev3
Still got it on wrong though
He's got it on part number '2' on that diagram,that part should have been fooked off with pipe going straight onto flame trap
This still would leave oil return to sump
A reply that Stu has'nt read properly
Old Jan 13, 2005 | 04:52 PM
Dave Henshall's Avatar
Dave Henshall
pic 1 : installed with the red bit pulled off the top.
pic 2: removed with the oil return and block connections to the bottom.
pic 3: block with it removed - see where the oil return from your new breather shuold go - into the sump where the old one came from.
and pic 4: with the new breather pipe fitted with a nipple into teh block - this is 1 port of your new breather.
Old Jan 13, 2005 | 04:54 PM
Dave Henshall
admitidly - this is all very much easier with the head off
Old Jan 13, 2005 | 04:56 PM
Dave Henshall
and my 'dead good' breather pic........
eddited to say - the pic SHOULD say oil return on the "passenger" side where the std seperator return it to
Old Jan 13, 2005 | 04:57 PM
3drstretch's Avatar
3drstretch
Why have you taken out the flame trap.
Old Jan 13, 2005 | 05:02 PM
CosKev3's Avatar
CosKev3
Don't think you really need it when running a aftermarket breather kit
because its not connected to inlet theres no chance of a flame going back
into sump
