gti tick over probs
Old Apr 11, 2010 | 08:49 PM
madblue's Avatar
madblue
Unhappy gti tick over probs
can any one help have a 1.8gti r reg with a tick over prob was told it was idle valve so had that changed which helped for a while.now when car is cold it ticks over at 1000rpm when it reaches normal temp rpm rises to 1500 when you drive car take foot of the throttle and car drives itself for a while and goes back to normal tick over 15oo rpm i have been told it could be a sensor so replaced
air temp sensor
temperature sensor
idle control valve
maf
throttle position sensor
im now at my wits end and may end up scrapping car as it has already cost me a small fortune and this is my last plea for help please help many thanks
Old Apr 11, 2010 | 08:54 PM
botters's Avatar
botters
competant bodger
did you fit a new idle sensor or a second hand one?
Old Apr 11, 2010 | 08:58 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
little breather that presses into the main breather at the front of the engine
its like a little insert that poke out teh top then has a breather tube coming off it and going up
i had similar probs, changed everything then tryed that and done Ł18 from ford
mine rattles, could remove it and see if yours does, new 1 didnt
i have since stripped the car i could send you mine for a tenspot 1st rec
just went out to take a picture
its pulled on in the last pic
also have maf etc
Old Apr 11, 2010 | 09:05 PM
madblue's Avatar
madblue
no thanks for yourreply when i brought car was told had new valve fitted at a garage
Old Apr 11, 2010 | 09:08 PM
madblue's Avatar
madblue
thanks for your reply and help do these picktures come from a zetec block as mine looks different thanks again
gcfcos
59
Oct 6, 2015 05:04 PM
Fiddy
21
Sep 29, 2015 06:10 PM
liamT74
Sep 23, 2015 10:24 PM
cossirob
Sep 16, 2015 07:39 PM
nikki.n.tom
Sep 15, 2015 08:20 PM
