spot the problem
Old Apr 11, 2010 | 07:23 PM
project rs's Avatar
project rs
Default spot the problem
somethings not quite right can you spot it
Old Apr 11, 2010 | 07:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What happened to the header tank?? lol
Old Apr 11, 2010 | 07:30 PM
project rs's Avatar
project rs
it went pop just after we showed an evo 10 how to move but was caused by this, causing head gasket to go and dumped all the chamber pressure into water side not looking good for central now and just as we got to 2 bar on the t34 too
Old Apr 11, 2010 | 07:43 PM
jonny s2's Avatar
jonny s2
oh no!
hope you get it fixed mate,
Old Apr 11, 2010 | 07:44 PM
Rob_DOHC's Avatar
Rob_DOHC
BOLLOCKS, sorry mate, looks like a new block from the picture! im not going to make it to central day any how now, fucking cars.
EDIT* Sorry thought i was looking at a picture of the block for some reason and the valve looked like a piston half way down the bore lol, so ignore the shite about the block!
Rob,
Old Apr 11, 2010 | 07:49 PM
project rs's Avatar
project rs
head went off before in crazycages care so with his skills should all be fixed by wednesday then as long as all the other bits turn up on time build it thur map fri travel down to central sat and thats cutting it fine as you can appreciate, might only be on actuator pressure though as we're trying a new cam out this time though to see if midrange can be improved think most of the wot tunning will be done on pod with datalogs
rstdave's Avatar
rstdave
Coor blimey, wounder mate!!! As been mentioned, seems everyone's having problems lol, typical but these things happen i spose....we all need to be ready at the same time for at least one event this season
Old Apr 11, 2010 | 07:58 PM
project rs's Avatar
project rs
thats the problem with trying to push so much through these old engines but thats part of the fun (when there working) seeing the newer hot hatches wondering why they can't shake this 20 year old escort of it's tail
Old Apr 11, 2010 | 07:59 PM
crazycage's Avatar
crazycage
was nice pushing that evo x out the way lol.
Old Apr 11, 2010 | 08:06 PM
project rs's Avatar
project rs
it was a shame i missed 3 at first otherwise it'd of been even easier but less fun, the noise the header made was a bit scary at first like a tiny bomb going off under the bonnet
Old Apr 11, 2010 | 08:12 PM
little bram's Avatar
little bram
ha bet that was loud. good how it poped that and not a pipe. wonder what would have happend if you had a metal header tank on
Old Apr 11, 2010 | 08:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Awsome!!!
2bar on a T34 with your manifolds and headwork.... that's some power!!
Old Apr 11, 2010 | 08:21 PM
Rob_DOHC's Avatar
Rob_DOHC
Got an email from the pod a few months ago saying you can take passengers up now, so you could get a trusted mate to drive whilst you map that what i was going to do before i realised my car would never be done in time
Old Apr 11, 2010 | 08:30 PM
project rs's Avatar
project rs
thats exactly what we're going to do but need to get it back together first and karlos we estimated that we must of been up around 270/80 by the duty on the greys and the way we pulled the evo etc in and a few other guages that we had but the proof is terminals at the pod
Old Apr 11, 2010 | 08:42 PM
little bram
what management you running mate and you on standard comp and running 2bar
Old Apr 11, 2010 | 08:48 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i think you must have been around that mate!
I'm a little annoyed that i've maxed the VXR ones out, but to be fair I was ragging the shit out of the turbo, so it's probably for the best anyway! lol
WHats the flow rate of the greys?
Old Apr 11, 2010 | 09:22 PM
project rs's Avatar
project rs
greys don't really have a flow rate each set is slightly different and i'm on megasquirt with a 7.7 comp ratio
Old Apr 13, 2010 | 07:50 AM
Rick's Avatar
Rick
Another stud and nut gasket failure!
Old Apr 13, 2010 | 02:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oh! I thought the head had broken up, or do you think thats a result of gasket failure?
Old Apr 13, 2010 | 02:38 PM
SiZT's Avatar
SiZT
Was it on No2 cylinder?
Old Apr 13, 2010 | 03:08 PM
crazycage's Avatar
crazycage
no3 mate
Old Apr 13, 2010 | 07:36 PM
Rick's Avatar
Rick
Gasket lifted and then the gases blowing across are concentrated on the edge and just cut through it like butter.
Rick.
Old Apr 13, 2010 | 07:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I see!
Old Apr 13, 2010 | 07:42 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Yip, that failure looks just like mine did.
How was it feeling up to that point? Strong?
Old Apr 13, 2010 | 07:50 PM
Rick's Avatar
Rick
C, i'll call you tomorrow to discuss.. You working?
Old Apr 13, 2010 | 07:58 PM
Christian and Beccy
#1 in Spelling Club
Discuss what? LOL.
No, day off tomorrow.
Old Apr 13, 2010 | 08:06 PM
SiZT's Avatar
SiZT
Originally Posted by Christian and Beccy
Discuss what? LOL.
7am wake up call for Christian?
Old Apr 13, 2010 | 08:29 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Fuel accumulator on EFI.........why
Old Apr 13, 2010 | 09:29 PM
project rs's Avatar
project rs
lazyness not got round to re-piping it all yet as going to have to move stuff round with new servo and gearbox thats planned soon
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
