3 door sierra with headlamp fault. help please?
Old Apr 10, 2010 | 06:18 PM
rs kyle's Avatar
rs kyle
Exclamation 3 door sierra with headlamp fault. help please?
Can anyone please help. when i put my sidelights on with the ignition on or the car running the inner main beam (spot lamp) on the driver side comes on, but with the ignition off just the side lights come on. I have the same problem on a friends 3 door too but cant seem to work it out
thanks kyle
Old Apr 10, 2010 | 06:27 PM
RS500/364's Avatar
RS500/364
Got the right relays in the right place !
Old Apr 10, 2010 | 06:28 PM
saph_Al's Avatar
saph_Al
Check your earths are all clean and tight and that no other bulbs are blown . your not runnin these aftermarket H.I.D kits or L.E.D's are you ?
Old Apr 10, 2010 | 07:22 PM
rs kyle's Avatar
rs kyle
no im not running hid or led kits, both cars do have aftermarket valeo headlamp units in them tho. not sure if they are at fault inside maybe
Old Apr 10, 2010 | 07:24 PM
rs kyle's Avatar
rs kyle
as far as i know yes. i checked them with the book
Old Apr 10, 2010 | 07:32 PM
PAUL S's Avatar
PAUL S
thats your problem then. Had this a few times myself with new headlights.
For some strange reason the new replacement 3dr headlights were fitted with the later saff internal looms which dont match the 3dr main loom.
Either swap out the little looms in the new headlights with the ones from the old set ( easy to do) or you have to rewire the new looms to suit.
I did it a few years ago so cannot remember which wires you need to splice, but there is a thread on here somewhere explaining what to do, I will see if I can find it
edited
the way to fix them is listed here
https://passionford.com/forum/techni...t-problem.html
Old Apr 10, 2010 | 08:29 PM
rs kyle's Avatar
rs kyle
edited
Thank you very much for the info. i will give it a go asap
Old Apr 15, 2010 | 10:10 PM
dooge's Avatar
dooge
dooge
i have the same problem on mine looked for the blue wire but could not see it on loomside, there is a blue wire to the inner mainbeam unit
dooge
Old Apr 16, 2010 | 12:33 PM
rs kyle's Avatar
rs kyle
dooge
i fixed both the cars with the problem by following the link. i think its a blue and green wire off the top of my head without looking at them.
it is on the driver side multiplug. also check the fuses because i did the wiring on the second car and still had a fault until i realised it blew a fuse too. let me know how it goes
Old Apr 16, 2010 | 09:51 PM
dooge's Avatar
dooge
dooge
ok will do
Old Apr 17, 2010 | 12:40 PM
They also get MASSIVELY brighter if you run relays and power wires/earth to each light unit, can hide the relays in the light shells, this is what I did with my xr4i my dads 4i and my sapphy, makes a big difference, as rid the car of high 20+ year old resistances, using just the std supply to trip the relays.
I used 1 dip and 1 main beam one each side for safety, so if a problem on 1 dip you still have 1 dip working.
Use some Philips Extreme H4 bulbs too.
Old Apr 18, 2010 | 08:11 PM
rs kyle's Avatar
rs kyle
Thank you very much for the advice. ill give it a go
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
