would a damaged vavle cause fiesta rs turbo to smoke?
Old Apr 9, 2010 | 10:48 PM
BIGMATT1's Avatar
BIGMATT1
Default would a damaged vavle cause fiesta rs turbo to smoke?
ive got a fiesta rs turbo thats smokeing after about 1 min of starting up or when you blip the throttle its also smokeing out the breather kit even on tick over, its had new turbo, baily breather kit, and recent head gasket, oil returns ok, just done a compression check and number 3 was down to 50 psi, all the others were about 150 psi tried it again with oil down the bore, and it was still 50 psi, tried it with oil down the bores and the rocker arms removed and it was still 50 psi, all the valves and rockers looked ok from above would a damaged valve cause these problems or is it the rings shot??
Old Apr 9, 2010 | 10:59 PM
phil_focus's Avatar
phil_focus
both fucked valves and fucked rings would cause it to smoke as you wont get compression so you wont be buring the fuel and it'll prob be leaking oil into the cyledar and then all that gets shoved out the exhaust and ignited by the other 3 cylenders.
i'm afraid its a head off job now to find the cause of the problem
Old Apr 9, 2010 | 11:12 PM
Fast Guy's Avatar
Fast Guy
Ring lands gone?
Old Apr 9, 2010 | 11:15 PM
RS Grant's Avatar
RS Grant
Made in Scotland
I'd go with rings... but you'll need to open it up and have a look see yourself now mate.
Cheers,
Grant
Old Apr 10, 2010 | 05:43 AM
Rsmat's Avatar
Rsmat
sounds like rings im afraid mate.
Old Apr 10, 2010 | 06:14 AM
nellyscossy's Avatar
nellyscossy
i'm for the ring brigade, a valve would cause a missfire,and your compression would be lower than that, and on a petrol engine not a lot of smoke,
Old Apr 10, 2010 | 08:38 AM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Ring a ding Ding!
Old Apr 10, 2010 | 09:55 AM
Oranoco's Avatar
Oranoco
Another vote for rings. CVH is a piece of piss to do though mate. Get yourslef a workshop manual and a torque wrench and get dirty. Great way to learn. My brotehr rebuilt his first CVH at 16 when my mum got him an Orion 1.6i Ghia as a plaything to learn on.
Old Apr 10, 2010 | 09:59 AM
Physio's Avatar
Physio
Old Apr 21, 2010 | 02:08 PM
Fast Guy's Avatar
Fast Guy
Did you find out what it was?
Old Apr 21, 2010 | 02:30 PM
rog's Avatar
rog
Old Apr 21, 2010 | 03:10 PM
macturbo's Avatar
macturbo
I would have thought top end myself.
If it were rings, the oil he put down the bore would have sealed the ring and gave compression.
Just a thought though.
Old Apr 21, 2010 | 03:45 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Surely a knackered valve wouldn't cause smoke? Just allow more to get out of its cylinder?
I'd have thought a knackered valve would cause low compression on one cylinder.
And if oil's been poured into the bores, surely that would smoke more as it's burned off? Just asking as I have only a simplistic understanding of such things.
When were the valve stem seals changed? Oil will be happy to run down the valve stems into the cylinder if the seals are shot.
Old Apr 21, 2010 | 07:17 PM
phil_focus's Avatar
phil_focus
sorry typo, meant the valve stem seals
Old Apr 21, 2010 | 08:55 PM
BIGMATT1's Avatar
BIGMATT1
thanks for the help, was just about to start stripping it when someone rang up, viewed the car and the problem and gave me what i wanted for the car and drove it away, still curious though would like to know what was causing it, means the cossy can have it garage back now!
Old Apr 21, 2010 | 08:58 PM
phil_focus's Avatar
phil_focus
oh well fuck it, new owner will have to sort it now.
que the new thread "i just bought this fiesta rs turbo and it smokes a bit, whats the problem"
Old Apr 22, 2010 | 09:43 AM
cozmeister's Avatar
cozmeister
More boost Igor!
I hope you printed this thread off for him.
paceo
Feb 3, 2016 10:31 AM
carlo
24
Oct 5, 2015 08:20 PM
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
knight19770
Aug 4, 2015 12:36 PM
