Would one different bolt in a bell/rotor setup cause vibration?
Old Apr 9, 2010 | 07:41 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default Would one different bolt in a bell/rotor setup cause vibration?
I'm looking at setting up an inductive speed sensor to 'read' one of my bell/rotor bolts for my dash.
The kit that i've got has a small magnet that i need to mount, my only concern is that to make it work correctly (sensor spacing etc.) i'll need to use a different bolt, around 6mm longer and mount a small magnet on the end of it.
My only concern is that obviously this will mean that at one point in every rotation there will be slightly more weight in one spot on the rotor/bell assembly.
Is this likely to cause a noticeable vibration?
Old Apr 9, 2010 | 07:57 PM
mrjenrst's Avatar
mrjenrst
if it did could you not use the same bolt's all around and just the magnet on 1?
Old Apr 9, 2010 | 07:58 PM
James998's Avatar
James998
You could get your wheels balanced on-car to eliminate this?
Old Apr 9, 2010 | 08:09 PM
markk's Avatar
markk
no it really would make no differance at all, if you think of the very small amount of inertia that little bolt could make so close to the hub, even if it was on the outside of an 18" rim, a couple of grams will do nothing, a stone in the tyre can weigh that much pal.
Old Apr 9, 2010 | 08:11 PM
Big Will_'s Avatar
Big Will_
I've argued this with myself for the last 15 minutes, convincing myself one minute it'd be fine and the next it'd be an issue
Old Apr 9, 2010 | 08:32 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
as andrew said pretty much!
that close to the hub would cause no problems at all, rubber getting stuck to slicks will cause more of a problem than an offset balance on the rotor.
Old Apr 9, 2010 | 08:38 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
If you are that worried, put the same bolt on opposite the pick up, and stick a few packing washers on to match the magnet weight
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
