fao plumbers/heating engineer peeps, is this a decent quote?
Old Apr 9, 2010 | 05:45 PM
john_p_b's Avatar
john_p_b
Default fao plumbers/heating engineer peeps, is this a decent quote?
we're needing a new boiler and a few other bits doing, currently got a antique back boiler and a fire that burns white so it's gotta go! details of the work as follows:
drain system
remove all tanks from roof space and airing cupboard
remove hot water cyl in airing cupboard and any unnecessary ancillaries
remove fire place and back boiler from chimney opening and cap off/remove all unnecessary pipework/fitting
supply and fit A rated, 30kw veissmann vitodens 100 condensing combi boiler to cupboard under stairs
run 20 white condense pipe externally to outside drain
run new 22mm gas pipe from meter to new boiler position
run hot and cold pipe work from new boiler to feed all outlets, across 1st floor landing
run 22mm flow and return pipe work from new boiler position and connect existing system on 1st floor
remove existing pipework in hallway and leave legs under floor to feed new radiator position in bathroom at later date
supply and fit new 400x450 rad in 1st floor toilet
supply and fit new 1200x600 double rad in rear bedroom
do all required electrical work
supply and fit wireless room stat
fit trv's supplied by customer
remove and relocate stop tap in kitchen
flush system and add necessary chemicals to protect
remove all waste from site
boiler comes with a 5 yr warranty
quoted £2050.53
it's a family friend quoting the work so is that a good price? seemed a lot at 1st but then theres a fair amount of work there.
would appreciate any input from those in the know or those who has recently had similar work carried out.
many thanks
Old Apr 9, 2010 | 05:56 PM
It's Czech Mate's Avatar
It's Czech Mate
Very reasonable if you ask me
Old Apr 9, 2010 | 06:04 PM
Shings's Avatar
Shings
I agree including the boiler and rads thats not a bad price at all.
Old Apr 9, 2010 | 06:11 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Is that plus vat?
Either way is a good price.
Old Apr 9, 2010 | 06:24 PM
john_p_b's Avatar
john_p_b
that's alll inc
Old Apr 9, 2010 | 07:15 PM
Steve the Plumber
You should also qualify for the £400 scrappage scheme too!!
Old Apr 9, 2010 | 07:19 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
sounds a good price that m8.
Steve
Old Apr 9, 2010 | 07:27 PM
foreigneRS's Avatar
foreigneRS
Testing the future
really? do back boilers qualify?
Old Apr 9, 2010 | 07:44 PM
john_p_b's Avatar
john_p_b
thought the scrapage scheme ended at the end of march?
Old Apr 9, 2010 | 08:20 PM
nellyscossy's Avatar
nellyscossy
the scrappage scheme has ended, all vouchers have been allocated, that isnt a bad price either, not a great fan of those boilers though..i would charge about the same
Old Apr 9, 2010 | 08:31 PM
eddie_od's Avatar
eddie_od
Yeah Got to say thats a good price
Old Apr 9, 2010 | 09:29 PM
TIFF's Avatar
TIFF
Chasing Radders
VERY VERY cheap............
Old Apr 9, 2010 | 11:18 PM
rstdave's Avatar
rstdave
Looks Damn cheap to me, had similar work but quite a few more rads and a worcester boiler and paid 3.5k, also done by someone i know through the trade so i don't think you'll get it done any cheaper!
Old Apr 9, 2010 | 11:22 PM
Fast Guy's Avatar
Fast Guy
Yes that's a good price. I've just paid £2500 for a new boiler (system change) without radiators. It's pretty much what your having done but with an old gas boiler not back boiler.
"run 20 white condense pipe externally to outside drain" 20mm? - My mate told me that Worcester Bosch have just told everyone to upgrade their outside drians to 32mm as they were having alot of problems with them freezing up during the cold weather.
Old Apr 10, 2010 | 12:56 AM
nellyscossy
how true, almost every other callout i had over the winter was frozen condense pipes, not all worcester bosch though, the regulations state that a max of 3m 21mm can be run outside and must be protected against frost, its just as well to use 32mm solvent weld, just looks a bit obtrusive, if not use a condense pump and you can run the pipe internally somewhere without the need for fall on the waste
Old Apr 10, 2010 | 06:44 PM
Steve the Plumber
I seen loads of the 21mm solvent weld pipes arent lagged so they freeze up!
5 year ago when I did the energy effiecency course we were told to lag them!!
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
S3an
Aug 11, 2015 07:26 PM
