checking £50.00 notes help
Old Apr 9, 2010 | 05:43 PM
morto's Avatar
morto
Default checking £50.00 notes help
hi all does anyone now the best way to chack £50.00 notes as you cant use ultra violet on them, i just want to be sure , i now you can buy the pens but need one for sunday , who sells them?
thanks
andy
Old Apr 9, 2010 | 05:52 PM
matts1's Avatar
matts1
maybe someone like office world or stationary outlet??
Also, do they have the red patch that SHOULD rub off on paper? Like the £20 notes do?
Old Apr 9, 2010 | 05:56 PM
mrjenrst's Avatar
mrjenrst
As he said ^ also the bank of england at the top of the note will be raised, very difficult to forge.
Old Apr 9, 2010 | 05:59 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
yeh as above cos of blind people they have a raised emblem
Old Apr 9, 2010 | 06:02 PM
7xrskb's Avatar
7xrskb
Just googled this info -
The ink should rub off onto a plain piece of white paper. Also when you hold a note to the light not only should you see the silver strip, you should see darker areas coming off them at right angles that look (supposedly) like piano keys.
The silver strip should be clearly visible and if you tear the note slightly across the strip, you should not be able to tear the through the strip.
The wording of the Bank of England should be raised if you run your fingers across it, as should the shape roughly centre bottom. Can't remember what shape it is for £50's but it's there to help the blind and visually impaired. It's a different shape for each note.
You should also have a hologram of £50 on the note.
Be aware you may have to put the note into the bank as many shops will not accept them, just in case.
You can also buy pens that tell you if it's fake.
More info here -
http://www.bankofengland.co.uk/bankn...ecurity_50.htm
Hope that helps.
Old Apr 9, 2010 | 06:14 PM
geordiegooner's Avatar
geordiegooner
send them to me mate i'll check them for you.
Old Apr 9, 2010 | 06:17 PM
gus's Avatar
gus
[quote=7xrskb;4841530]
quote]
thhis has drove me mad many times
its legal tender but no one wants to touch them
Old Apr 9, 2010 | 06:24 PM
RS500/364's Avatar
RS500/364
Just go down the Gypsy site and you will know there fake save buying the pen !
Old Apr 9, 2010 | 06:30 PM
morto's Avatar
morto
thanks for all your info guys just want to make sure i dont get ripped off
andy
dojj
Sep 29, 2015 10:32 PM
