escort cosworth fuel pressure???
hi can anyone tell me what fuel pressure i should run on my stage 3 escort cosworth ?????? ive just fitted a fse power boost pressure reg what pressure at idle for stage 3 with or without vac?????
i was given a fse reg so thought id put it on!!! just wandered if i could up the pressure if it would help in any way?? ive got a 1992 escort cos with stage 3 pts chip, 3 bar map sensor, bosch 803 green injectors, rs 500 intercooler, t34 turbo, collins actuator, bosch 023 intank uprated fuel pump, running 1.5 bar boost???
Because there crap to be brutally honest mate, its not worth melting your engine over something like this especially when a std one is well up to the job and works better than the one you have fitted. Mark is one of the top tuners in the country he knows what he is talking about when he says put it in the bin lol
ok guys thats fair enough thanks for your honesty!!! i will refit my original one tommorow!! i know marks good he sorted my last saph cossie for me!!! one more question what plug gaps should i be running with 25 psi boost?? ive got genuine ford plugs in recomended by woodford motorsport??
On a stock coil 25thou works well.
Mark
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
