Ford 5.0, 302 V8 to MT75 4x4conversion parts
CNC Billet aluminium lower sump section.
CNC Chrome molly tool steel flywheel to take XR ring gear and Cosworth clutch
CNC Billet aluminium adaptor plate
Chopped up XR4x4 sump
Still plenty to do (some machining and a fair bit of welding) but most of the hard work is done, there is over £350 worth of raw materials in this lot and a really silly amount of drawing and machining time.
Will take £350 for flywheel, engine to gearbox adaptor, sump and sump adaptor.
Flywheel comes with ring gear.
Conversion uses V6 MT75 as it has longer input shaft
PM me and I will get back to you.
Mark
Mark
borboyous
Aug 22, 2015 11:17 AM
muz
Aug 16, 2015 12:57 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
