Blue Smoke FRST
Old Jan 12, 2005 | 04:01 PM
chRiSbeddall's Avatar
chRiSbeddall
Default Blue Smoke FRST
Just because its smoking on start up and when idling also when you let your foot off the gas,(generally all the time ) does this mean its the turbo as i dont want to fork out loads and it sttill smoke.... ive been told it could be the stem seals?
Any help/advice on this would be great thanks
chRiS
Old Jan 12, 2005 | 05:02 PM
Red16's Avatar
Red16
sounds like stem seals as its smoking from a cold start
but also turbo oil seal as its smoking when you back off the throttle, my frst done the same, changed the turbo n the smoke stopped when backing off the throttle.
Old Jan 12, 2005 | 06:11 PM
Moonie's Avatar
Moonie
Stem seals are only a couple of £ and are easy to replace. I would be trying them first before replacing the turbo!
Old Jan 12, 2005 | 06:17 PM
chRiSbeddall
Cheers ill do the stem seals anyway just piece of mind then get the turbo done
cheeRS
Old Jan 14, 2005 | 04:39 PM
ian rst's Avatar
ian rst
Mine was chuffin a bit of blue and i did the stem seals but no joy it was the turbo in the end.
Old Jan 14, 2005 | 06:38 PM
sammy's Avatar
sammy
i would do the valve stem oil seals first, should only cost about £100 max, but if you have a t2 turbo it's usually that bought to many t2's, ive now learn't my lesson & fitted a stage2 t3, its reliable
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
