FRST engine into xr3i efi cabby
Old Jan 12, 2005 | 03:28 PM
lazy_arse_pie's Avatar
lazy_arse_pie
Default FRST engine into xr3i efi cabby
im in the prosses of starting a escort cab project and would like the frst engine fitted in which i know somebody who did my last engine conversion in my fiesta who is prepered to do it for me but we require some info etc , what exhaust is used for this sort of conversion ? woudl the original loom be ok for the engine ?
also any other help or info about the conversion would be great
cheers Pie
Old Jan 12, 2005 | 03:51 PM
Robin's Avatar
Robin
in gudie section on ft.com it shows u how to change the loom from 2i to rs, imagane its the same process
flashpoint's Avatar
flashpoint
Look http://cgi.escortcabrioletclub.co.uk...?showtopic=920
Steve
Old Jan 12, 2005 | 03:52 PM
cossiecrew's Avatar
cossiecrew
hows it goin rob lol you get around dont ya
Old Jan 12, 2005 | 03:56 PM
lazy_arse_pie
cheers will look
Old Jan 12, 2005 | 04:05 PM
Robin's Avatar
Robin
u know it mate
here u go chap
http://www.fiestaturbo.com/phpBB/viewtopic.php?t=77331
Old Jan 12, 2005 | 04:43 PM
K18NEO's Avatar
K18NEO
Ive done mine, but ive got a mk5 cabbie with the ERST.
Old Jan 12, 2005 | 04:52 PM
skeld's Avatar
skeld
use a s2 exhaust, manifold and down pipe.
and get your hands on a ofab fez turbo ecu and on the ecu connector :
1) At the ECU, pin no. 27 (marked on the multiplug, brown wire) needs moving to pin 8, which is empty (this is the CO adjuster signal wire).
2) Pin no. 45 (brown/yellow) needs moving to pin 27 - this is for the MAP sensor.
3) EDIS Module pin 2 (blue/yellow) may now be disregarded as it is not used by the 0FAC ECU (pin 28 on ECU).
did this conversion last week end. still got to get an ecu tho so its not all wired up.
you can use an ofac ecu aswell but the ofab is easier. but can only use a 2 bar map sensor.
Old Jan 13, 2005 | 01:45 PM
lazy_arse_pie
cheers for the info and help chaps
Old Jan 13, 2005 | 01:48 PM
Sticky.'s Avatar
Sticky.
What happened to leaving it as a run around while you save for the escort cossie
How long before you get bored with this one
Old Jan 13, 2005 | 01:54 PM
lazy_arse_pie
Old Jan 13, 2005 | 07:55 PM
scort's Avatar
scort
www.rsbible.co.uk
In depth information about this conversion.
PS, you still interested in any cabbie parts?
Steve
EoinXR3
Sep 7, 2015 05:44 AM
s1turboman
Aug 29, 2015 04:27 PM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 17, 2015 12:21 PM
marky_g
Aug 15, 2015 10:43 AM
