Small turbo inlet with throttle body onto 2wd yb
Hi has anyone used, done or know anyone who has used this set up before? Any info would be great. Does anyone know if the small turbo throttle position sensor is conpatible with a l8ecu. Both small turbo and pfo9 tps are 3 pin but do they work on the same values?
I know using a 2wd or 4wd throttle body would be easier but think using the bigger throttle body will be worth the bother.
I would be very grateful for any info.
Matt Baxter
Sep 16, 2015 08:30 PM
