Snapped tensioner bolt
Old Apr 7, 2010 | 07:23 PM
neil73's Avatar
neil73
Default Snapped tensioner bolt
I've snapped the rear bolt tightening the tensioner, my own stupid fault, how can I remove it? I don't know if there are threads showing or not as I've shut the bonnet and come inside, does the bolt go right to the end of the threads or does it just tighten to the tensioner? Does anyone know what size the bolts are?
Cheers in advance, neil
Old Apr 7, 2010 | 07:52 PM
studabear's Avatar
studabear
take the tensioner off and upload a picture, I will try and advise you from there
presume you mean cambelt tensioner
Old Apr 7, 2010 | 09:13 PM
neil73's Avatar
neil73
Yes mate it's the cambelt tensioner, there are about four threads showing so going to try to turn it out tomorrow
Old Apr 7, 2010 | 09:49 PM
cj_rst's Avatar
cj_rst
S2 RST
Might be lucky and it'll turn out, failing that, drill the body of the screw out and re tap the thread
Old Apr 7, 2010 | 09:54 PM
gaz s1's Avatar
gaz s1
my car was being tuned by power engineering years ago and my cam belt was deemed lose so they tightened it and snapped one of my bolts off and left me to my own devices to get it home(it goes without saying i never used them again).
The way me and my mate got it out was to take the tensioner off and there was a little stub sticking out of the block so we kept dropping bits of weld onto it till it built up and undone it with mole grips, hope this makes sense and good luck
Old Apr 7, 2010 | 10:12 PM
studabear's Avatar
studabear
a stud extractor should get it out easy enough if there's a bit stickin out, whereabouts are you neil73
Old Apr 8, 2010 | 09:20 AM
Karlos G's Avatar
Karlos G
Balls Deep!
How tight were you doing it?? The torque setting is only about 20ftlb or something fairly low like that! lol
Old Apr 8, 2010 | 10:13 AM
gaz s1's Avatar
gaz s1
shame pe didnt know that
Old Apr 8, 2010 | 03:04 PM
neil73's Avatar
neil73
I'm in sheffield mate, thanks for the tips guys going to try and get it out later, will let you know how I get on
Old Apr 8, 2010 | 04:34 PM
neil73's Avatar
neil73
All ideas are greatly recieved mate
Old Apr 8, 2010 | 08:51 PM
rsmark86's Avatar
rsmark86
lol ive done that a couple of times lol and go to ford and get a couple of new ones as they are about 40p each .
Is it snapped flush if it isnt remove the tensioner and get a small pair of grips on the and lock them tight and slowly work it out .
if it is snapped flush u can get a tool called a easy out its like a stud extractor but acts like a drill bit as you wind it in till its tight , them reverse it locks in the stud and will wind it out. you can get them from most motor factors or snap on and maybe halfords.
Old Apr 8, 2010 | 08:55 PM
botters's Avatar
botters
competant bodger
just weld a nut on the end let it cool and wind it out saves doing any drilling etc...
Old Apr 8, 2010 | 09:03 PM
rsmark86's Avatar
rsmark86
this is a very good idea if you can get a welder or if a friend can help
give it a try
Old Apr 9, 2010 | 11:01 AM
neil73's Avatar
neil73
That's the next thing I'm going to try tomorrow, cheers for the help fella's
Old Apr 10, 2010 | 11:28 AM
neil73's Avatar
neil73
Sorted it, had to take the rear engine mounting off and get some mole grips and turn it out, thanks for all the help and ideas
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
