The Brooklyn 2.4 Conversion??????
Old Jan 12, 2005 | 12:11 PM
TIFF's Avatar
TIFF
Chasing Radders
Default The Brooklyn 2.4 Conversion??????
I know that it was offered from the main Dealer in Redditch aka Brooklyn RS Ford
What was the spec on the Brooklyn 2.4 conversion?
Who did the work?
Was it covered on the cars warrenty?
Old Jan 12, 2005 | 12:16 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If it uses the same crank as the 2.4 conversions I have seen, it is a normally aspirated long throw crank that was only rated to 400lb ft of torque .
I have seen one in two pieces that had a T4 bolted to the engine .
Old Jan 12, 2005 | 12:19 PM
Billabong's Avatar
Billabong
I have soon one in two pieces
Is that Norf*ck for seen?
Knew you'd be first to reply to this topic
Old Jan 12, 2005 | 12:21 PM
TIFF's Avatar
TIFF
Chasing Radders
I thought you would reply Mike
Just talking to a lad that SAID he had one from new years ago.
Wanted to know some specs and info on them
Old Jan 12, 2005 | 12:22 PM
gaz1's Avatar
gaz1
I went out in the brooklyn car, from what i remember it went very well and pulled hard all the way
but was expensive
Old Jan 12, 2005 | 12:31 PM
Mike Rainbird
Caraholic
And was like a CVH above 5500 rpm .
Old Jan 12, 2005 | 12:58 PM
Sticky.'s Avatar
Sticky.
Jonno ^NUTTER^ has the silver saph from the Fast Ford Cosworth magazine.
The 2.4 Brooklyn one
Old Jan 12, 2005 | 01:20 PM
GUZZLER's Avatar
GUZZLER
power engineering done a 2.4 conversion with a proper steel crank & rods.
Old Jan 12, 2005 | 03:02 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
any piccy of jonnos car?
Old Jan 12, 2005 | 03:07 PM
Sticky.'s Avatar
Sticky.
Yeah in the Fast Ford Cosworth mag Gus
It was the one with the black 500 & the escort cossie, they all had the 2.4 conversions by Brooklyn.
Old Jan 12, 2005 | 03:20 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
I enquired about this a couple of years ago, if you wan to know more give brooklyn reditch a ring on 01527 521212, ask for roger in parts, he will tell you everything you need to know! from what I remember, it is a 91mm stroke crank, the sump is modded along with oil pick-ups to clear the extra throw, and it makes 440BHP and 450Lbs/ft but has a usable rev celing of approx 6000RPM
Old Jan 12, 2005 | 03:25 PM
Rhys's Avatar
Rhys
what it only revs to 6000RPM? Shit thats low for a cossie but still not bad power and Tourque.
Old Jan 12, 2005 | 03:29 PM
RWD_cossie_wil
remember that the crank throw has been massivly increased, hence loosing the ability to rev, but you get massive torque everywhere
Old Jan 12, 2005 | 03:31 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
6000rpm? Surely thats more to do with head/cam/turbo spec than anything else?
Or is 6000 the safe limit before the crank snaps clean in half?
Its like when people do 2litre ZVHs and claim they dont rev above 5500, but its cause they still using a pussy T3 so by time its hit 5500rpm the turbo (esp the exhaust side) is all out of flow...
They put a bigger job on it (.63 T34) and suddenly it revs through no bother.
Old Jan 12, 2005 | 03:32 PM
rsjp's Avatar
rsjp
it was devoloped and built by a very good friend of mine who still works there on the cossies if they have any in for service ,if you need anymore imformation tiff i will give him a call and get all the parts and spec
jp
Gaaables's Avatar
Gaaables
my mate had a british racing green 4x4 shaffy with a brooklin 2.4 conversion. went very very well (approx 420bhp) had no problems at all, used to spin all 4 wheels
Old Jan 12, 2005 | 03:58 PM
Mike Rainbird
Caraholic
Before you buy one of these, find out EXACTLY what crank it has in it, as the ones I have seen run the WRONG one (as in a normally aspirated (still steel, so that means nothing ) crank that is only rated at 400lb ft) . If they have nothing to hide, they won't mind telling you the supplying company and crank reference number.
Old Jan 12, 2005 | 04:07 PM
Jon(m600)'s Avatar
Jon(m600)
So are these 2.4 conversions simular to the Collins 2.3 thats in my car?
Old Jan 12, 2005 | 04:12 PM
Mike Rainbird
Caraholic
Jon,
I don't think so, as the Collins conversions have seen quite a lot of boost from a T4. The n/a cranks split in two the instant they see 2 bar .
Old Jan 12, 2005 | 04:18 PM
bud-weis's Avatar
bud-weis
Football Cwazy
they had an imperial blue one up for sale badged as 2.4 brooklyn conversion til not so long ago. i'm sure it was £18999 ? they also had a very nice imperial left hooker for £16000!!
Old Jan 12, 2005 | 04:19 PM
RANJ's Avatar
RANJ
is this andy fisher conversion from brooklyn
Old Jan 12, 2005 | 04:28 PM
Billabong's Avatar
Billabong
Ranj, I believe that is JP's engine man.
CozzyBrom's Avatar
CozzyBrom
mike ya wromg again m600 has seen 2.5 bar at brunters with me driving before i blew his clutch up lauching it
it ran out of revs at 7000 due to gearbox but was around 165 mph
and the crank didnt snap in to bits
Old Jan 12, 2005 | 04:33 PM
Billabong's Avatar
Billabong
Brom, you need to re-read Mike's reply, here this is yours....
Old Jan 12, 2005 | 04:35 PM
EscortWRC's Avatar
EscortWRC
The problem with lengthening the stroke and keeping the block the same is that the rods get REALLY short. Short rod/stroke ratio engines do NOT like to rev.
You can only make the compression height *so* short before you start running into the ring pack, and after that you're stuck.
TIFF's Avatar
TIFF
Chasing Radders
So is this Andy Fisher the guy that builds them for Brooklyn??
Old Jan 12, 2005 | 04:36 PM
Mike Rainbird
Caraholic
Karl "I can't read or type, but I can build a tractor" Bromley - in yo ass .
Old Jan 12, 2005 | 04:44 PM
rs4steve's Avatar
rs4steve
yes mine is an andy fisher built engine mine is back in bits and is in his magical hands again
Old Jan 12, 2005 | 04:51 PM
rsjp's Avatar
rsjp
correct bill andy fisher builds our engines ,the last 3 produced 500+ bhp
jp
Old Jan 12, 2005 | 04:59 PM
Jon(m600)'s Avatar
Jon(m600)
Nice to know M600s 2.3 conversion has proved to be "Brom proof"
Old Jan 12, 2005 | 08:26 PM
CozzyBrom's Avatar
CozzyBrom
tractors are good for squashing snails like you mike when i over take them on the grass
Old Jan 12, 2005 | 08:53 PM
Tony Ryan's Avatar
Tony Ryan
Mike , i think i know the rest of the split in two n/crank in a big engine story scenario !! I believe that Harvey sold MC a new engine after this ! If you know what i mean
Old Jan 14, 2005 | 01:59 PM
Mike Rainbird
Caraholic
Tony,
I don't think MC had much choice - I saw the state of the aftermath .
Old Mar 7, 2013 | 05:15 PM
dodge8283's Avatar
dodge8283
Any of these still going about ?
Old Mar 7, 2013 | 05:25 PM
POLARIS ESCOS's Avatar
POLARIS ESCOS
I had one up until last year when one of the rods bent it was decided when i rebuilt it i returned back to 2 litre bottom end but i still have the block and crank and rods and pistons ect from the 2.4 engine at home so one day i will prob get a set of rods and pistons made and build back up as it was so responsive and had over 520 lbft really low down
Old Mar 7, 2013 | 05:54 PM
cossiefrank's Avatar
cossiefrank
The rs500 was 2lt not 2.4 And graham (polaris escos) has the escort from the mag
Old Mar 7, 2013 | 09:48 PM
dodge8283's Avatar
dodge8283
I was speaking to Andy while he had your engine so i knew yours was still going just wondered about the others. Lovely car yours pal
Old Mar 7, 2013 | 09:54 PM
POLARIS ESCOS
Good bloke andy and he's a true gent and not out to rob you I wouldn't hesitate in sending an engine to him
Carnt wait to get mine mapped in the spring and see what power can be had out of it
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
