haynes manual translations
Old Apr 6, 2010 | 11:19 AM
danzul's Avatar
danzul
Default haynes manual translations
as follows;
Haynes: "This is a snug fit"
Translation: "Beat repeatedly with hammer"
Haynes: "Rotate anticlockwise"
Translation: "Clamp with molegrips, beat handle repeatedly with hammer"
Haynes: "Pry"
Translation: "Hammer screwdriver into"
Haynes: "Undo"
Translation: "Locate aged can of WD40. Hammer can to increase pressure. Squirt everywhere"
Haynes: "Retain tiny spring"
Translation: "What the Hell was that? It nearly had my eye out!"
Haynes: "Apply moderate heat"
Translation: "Placing your mouth near it and huffing is not moderate heat"
Haynes: "Press and rotate to remove lamp"
Translation: "Smash glass. Dig out bayonet with pliers"
Haynes: "Carefully"
Translation: "You are about to cut yourself badly"
Haynes: "Lightly"
Translation: "Start off gently, build up pressure until veins are standing proud of your forehead. Reread the manual because what you are doing can in no way be described as 'lightly"
Haynes: "Weekly checks"
Translation: "If it ain't broken, don't fix it"
Haynes: "Routine maintenance"
Translation: "If it ain't broken, it sure as hell is about to be"
Haynes: "Compress"
Translation: "Squeeze with all your might, club with wrench, jump upon, back car over, throw at garage wall, then search for battered component in darkest corner of garage while cussing repeatedly under breath"
Haynes: "Inspect"
Translation: "Squint really hard, pretending you know exactly what you are looking at. Declare in a loud, knowing voice, "Just as I thought. It's going to need a new one"
Haynes: "Retaining nut"
Translation: "The hexagonal metal block you just shaved irreparably with
an imperial size spanner"
Haynes: "Using a suitable drift"
Translation: "A paving slab will suffice"
Haynes: "Get an assistant"
Translation: "Prepare to humiliate yourself in front of someone you know"
Haynes: "Turning the engine will be much easier with the plugs removed"
Translation: "Turning the engine will be much harder, and will probably be accompanied by some distressing noises you've never heard before. Once that panicky, clenched feeling in your stomach has subsided, continue as if everything is fine"
Haynes: "Refitting is the reverse sequence to removal"
Translation: "Discard leftover screws and washers"
Haynes: "Prise away plastic locating pegs"
Translation: "Bend back and forth repeatedly until it snaps"
Haynes: "Everyday toolkit"
Translation: "Ensure you have your RAC membership card handy and have charged your mobile phone"
Old Apr 6, 2010 | 11:30 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
That was a good email, might have to send that round again
Old Apr 6, 2010 | 11:50 AM
4x4 S2 Cossie's Avatar
4x4 S2 Cossie
Lol - so true!!
Old Apr 6, 2010 | 11:51 AM
danzul's Avatar
danzul
hope it wasnt a re-post, sorry iof it was
Old Apr 6, 2010 | 12:08 PM
R4N SS's Avatar
R4N SS
quality
Old Apr 6, 2010 | 01:19 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
top notch that... and 100% true
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
THE RADMAN
Sep 19, 2015 12:57 PM
markk
Sep 9, 2015 08:11 AM
fuzzy
Sep 4, 2015 10:11 PM
