anyone here run with MoTeC M4 with Zetec engine??
Old Apr 4, 2010 | 11:33 AM
szabyk RST's Avatar
szabyk RST
Default anyone here run with MoTeC M4 with Zetec engine??
I would like to find ref / sync settings with factory sensors....
I'm not sure that I have with the current setup...
thanks
Old Apr 6, 2010 | 04:13 AM
szabyk RST's Avatar
szabyk RST
anyone?
I would really appreciate
Old Apr 6, 2010 | 07:24 AM
oldford's Avatar
oldford
I use Motec's M600 and M800, but shouldn't be that different.
So what kind of sensors are you using? Usually they are magnetic sensors. Hall-sensors require a 8 volt feed and magnets as triggers.
What kind of trigger wheels do you have? 60-2? 36-1?
And for the camshaft sensor?
Old Apr 6, 2010 | 09:05 AM
szabyk RST's Avatar
szabyk RST
hi
I use magnetic sensors for factory ...
factory flywheel 36-1 trigger
and the factory cam sensor..
Old Apr 6, 2010 | 10:18 AM
oldford's Avatar
oldford
In General setup select Main setup.
Ref sensor type = 2, Sync sensor type = 2, Ref / Sync mode = 51
Crank ref teeth = 36, Tooth ratio = 50. Crip = ??? (Depends on your engine)
Read help for all these topics. For ref/sync mode press F1, then select mode51-54 and press enter.
Old Apr 6, 2010 | 10:32 AM
szabyk RST's Avatar
szabyk RST
These settings are running for me ..
then they are good!
thank you
JoeyBoyden
Jan 4, 2024 02:36 PM
gingerturbo
Aug 18, 2015 07:58 PM
IAN RS2k
Aug 18, 2015 07:51 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
knight19770
Aug 4, 2015 12:36 PM
