fiesta rs turbo crank posistion sensor
I have an s2 running cossie managment i have just got a new bottom end with an efi flywheel and the cut out on the block can i just use the fiesta rs turbo crank posistion sensor on the fly wheel instead of the tdc and will it work in the same way or do i still need to use the tdc sensor and have the fly wheel abapted if any one can give me some advice this will help me a grate deal thanks
hi, ive got cossie management on my 2ltr zvh frst & gonna do my tdc on the flywheel next time i change the g/box (never to long!), cant remember for sure which crank sensor to use (think its the zetec 1 if its a zetec bottom end) i have seen it mentioned on www.fiestaturbo.com or a link from there, poss in guides&faq. as for the flywheel its easy look on www.zetec-turbo.co.uk under management, good luck mate
paceo
Feb 3, 2016 10:31 AM
Zoggon
Aug 10, 2015 10:39 AM
