just tried fitting dump valve
Old Apr 2, 2010 | 10:13 AM
Luketehpro's Avatar
Luketehpro
Default just tried fitting dump valve
but dont have a fecking clue, so unless any1 got any detailed pics gonna take it to the garage, it looks fairly simple but i dont want to feck any thing up by putting pipes wrong way
Old Apr 2, 2010 | 10:23 AM
waynefrst235's Avatar
waynefrst235
What kinda car is it?
Old Apr 2, 2010 | 10:24 AM
kieran265's Avatar
kieran265
is this in a focus rs mk1?
Old Apr 2, 2010 | 10:27 AM
daviddunlop83's Avatar
daviddunlop83
What car is in on for a start?
Edit, beat me to it
Old Apr 2, 2010 | 10:29 AM
Luketehpro's Avatar
Luketehpro
yeah focus RS mk1 sorry im stupid
Old Apr 2, 2010 | 03:15 PM
Imperial-blue-rs's Avatar
Imperial-blue-rs
You probably won't want to hear this but most FRS's run like shite after fitting one of those, stalls and runs ruff etc...
They prefer the recirc type, with an induction like a Gen II they sound the same aswell I've heard.
Do a search on the RSOC and you will see what I'm on about.
Mark
Old Apr 2, 2010 | 04:40 PM
Luketehpro's Avatar
Luketehpro
ive read alot about the problems ure saying and ive bene back and forth ive bought it nw and they said i could take it back if i had problems, ne way there are so many ppl saying there fine and they do and dotn work, jst thgt id see for myself
Old Apr 6, 2010 | 12:45 PM
Irish aRSe's Avatar
Irish aRSe
Running both the recirc valve and an atmospheric dump valve is a recipe for disaster. They tend to overfuel and run poorly as the lads have said but in theory you should be able to run the atmospheric type if you blank off the recirc valve pipes and take out the recirc valve completely, then just run the atmospheric valve on its own.
I have seen guys do this before and they say it runs fine but to be honest i have a gen 2 and a forge recirc valve and it sounds as good as an atmospheric dump valve and the car is running as Ford intended.
anyway to cut a long story short don't run the 2 of them together and i would give back the atmospheric dump valve and get yourself a gen 2 induction instead. You will get more power and its a far better mod for your money.
Old Apr 6, 2010 | 05:41 PM
moondustka's Avatar
moondustka
Boooost!
Somewhere on here someone said you had to reset/disconnect the ecu after fitting an atmospheric one, to avoid the stalling etc. As the ecu is self-learning.
Unsure what to do with mine, when I get the engine in, as I don't really like the dump valve noise, prefer chatter, but guessing the turbo doesn't have a 360 bearing??
Old Apr 7, 2010 | 03:41 PM
Luketehpro's Avatar
Luketehpro
i dont no the answer to ure question moondustka, but i managed to fit my baileys dump valve just an normal atmospheric one ( as thats what the guy at baileys sed worked best (rang them up) ) buti fitted it and its fine dosent stall, didnt disconnect battery sounds abit more gruff but just same wi a noise not too loud, altho my car is standard apart from the valve
RUBY123
Oct 22, 2023 12:04 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
Red_bull
Aug 9, 2015 08:34 AM
