cossie sus on 1,8LX
Old Mar 16, 2004 | 04:15 PM
Default cossie sus on 1,8LX
will 2wd cossie springs + dampers fit a k reg 5door XL?
thanx for any help
Old Mar 16, 2004 | 04:45 PM
Neal's Avatar
Neal
Completely diff i think.rear arms are bigger too......
Old Mar 17, 2004 | 07:59 AM
bugger thanx anyway at least i haven't bought anything yet
Old Mar 17, 2004 | 10:46 AM
anyone know where i can get cheap lowering springs? i've found pi's for Ł73 on one site but onther than that only Ł99 up
also whats the best deal i could hope for, for springs + dampers?
Ta
Old Mar 18, 2004 | 08:55 AM
foreigneRS's Avatar
foreigneRS
Testing the future
they will fit, as long as you've got 2wd cossie stuff. the damper will go into your hub at the front, unless you also want to go to cossie hubs with 4 pots and vented discs, in which case you should get the whole cossie front end (including anti roll bar which is much thicker than a 1.8).
at the rear, springs and dampers will fit no probs. if you want the cossie arb, you might not be able to unless your trailing arms already have a mounting point for it?
it's a very cost effective mod and will improve the handling no end. i did it on a 1.6 3 door that i picked upand put 2wd cossie suspension and brakes on and dropped in a 2.0i with sport injection cam and a ported and skimmed head. was a good little motor 'til it met the armco on the nurburgring.
Old Mar 18, 2004 | 12:40 PM
thank you your a star
Old Mar 18, 2004 | 01:26 PM
do you mean if i keep the 1.8 brakes it'll be a strait swap of spring+dampers?
Old Mar 18, 2004 | 03:00 PM
foreigneRS's Avatar
foreigneRS
Testing the future
should be, as far as i remember. i think that there are only two different damper body diameters, one for all 2wd and one for all 4x4. best measure 'em up before buying though.
Old Mar 18, 2004 | 03:05 PM
thank you
Old Mar 18, 2004 | 04:02 PM
JamesH's Avatar
JamesH
I see you've made it then!
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
