Blue smoke when pulling away
Hi,
Got a small problem with my S1, if I sit at idle for more than 30secs or so, when I pull away it chucks out loads of blue soke out the back. It doesn't smoke when it starts up or on boost or when lifting off.
Had new stem seals about 1000miles ago, just had an oil change too with fully synthetic 5w50, but still doing it.
Any ideas?
Thanks
Any ideas?
Thanks
yeah blue on boost too, going to whip the exhaust off tomorrow and see if theres any oil in the downpipe as the charge pipes are clean.
if it's only a hint of blue, then i wouldn't panic, mine has a bit now and then when coming on boost apparantly (can't see it when i'm giving it some).
nothing any other time that i notice.
definitely sounds turbo related to me though as i've had a few fail in the past.
it has brand new bailey breather pot and fitting kit, will check them anyways.
Little update, took turbo off today to find theres nothing wrong with it. Checked plugs to find number 3 was covered in oil, done a wet compression test to find piston rings are knacked. Going to build a new forged engine, got to choose between a CVH or Zetec now.
Got a big valve ported and polished head and running cosworth managment. Will be easier to chuck another CVH in as its all setup for it, but 16v Zetec does sound tempting, even if its just to get rid of the CVH rattle lol
Steve Escos
Oct 1, 2015 06:57 AM
