Steering Wheel Problem
Old Apr 1, 2010 | 04:07 AM
turbomook's Avatar
turbomook
Default Steering Wheel Problem
My small turbo Escort Cosworth is fitted with a momo steering wheel, how ever i was wanting to fit an original one with air bag.
I bought a steering wheel and was told it was a ST escos one, when fitting it everything lined up, and the steering lock work but the two prongs from the indicator stalk never touched the back of the sterriing wheel, so the horn push button would not work?
Does anybody know if maybe ive bought the wrong steering wheel or do i have a different problem?
Thanks
Old Apr 30, 2010 | 01:32 PM
AJC's Avatar
AJC
put this on the escort forum mike, that should help
Old Apr 30, 2010 | 04:50 PM
paul16v's Avatar
paul16v
Monte 087
I know you cant get a boss to fit an escos with an airbag you have to change the ingnition housing to one from non airbag model so that aftermarket/ford boss's will fit so this is probably what has happened.
JoeyBoyden
Jan 4, 2024 02:36 PM
YODI
Aug 30, 2015 01:12 PM
RockinRein
Aug 19, 2015 07:08 PM
Roosie
Aug 19, 2015 11:52 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
