Got to try my Quiafe ATB tonight!
Old Mar 31, 2010 | 09:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Talking Got to try my Quiafe ATB tonight!
Had a chance to open it up round some tight bends on the way back from Ipswich tonight... In 2nd gear once the wheels broke traction and you would normally expect to understeer accross the road I was happy to find the LSD pulling the car nicely into the corner!!
Great upgrade well pleased
Old Mar 31, 2010 | 10:17 PM
1223456's Avatar
1223456
what is it like in a straight line mate? does it dig in or still spin as easily
Old Mar 31, 2010 | 10:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It's far better than a normal LSD IMO, the wheels do not spin as easily no...... But obviously depending what gear and how much torque you run your always going to be able to break traction if you try! lol
Old Mar 31, 2010 | 10:35 PM
boothy's Avatar
boothy
How much are they mate....
Old Mar 31, 2010 | 11:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
IIRC about £500 mate
Old Apr 1, 2010 | 08:12 AM
Antti O's Avatar
Antti O
I found quaife 500£ without VAT so it will be more.
My diff is broken so i have to replace it with something good.
Old Apr 1, 2010 | 09:30 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah I think nearer £600 is more like it.
Old Apr 1, 2010 | 12:06 PM
Chris69's Avatar
Chris69
Originally Posted by Karlos G
Had a chance to open it up round some tight bends on the way back from Ipswich tonight... In 2nd gear once the wheels broke traction and you would normally expect to oversteer accross the road I was happy to find the LSD pulling the car nicely into the corner!!
understeer you mean, run wide etc
oversteer is a rwd attribute and will only be seen with lift off oversteer in fwd
sounds good though, i've only been in one rst with Quiafe Diff before and i thought it was pretty dam impressive
Old Apr 1, 2010 | 12:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ooops! lol
Yes I ment understeer!
Old Apr 1, 2010 | 08:02 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i have considered getting one, but have now ditched any plans to fit a decent bc/ib5 box and am lining up an mtx conversion so will need an atb for then.
good to hear a review none the less
Old Apr 1, 2010 | 08:28 PM
rstdave's Avatar
rstdave
Glad you like it mate, had one for a few years now and really can't rate it highly enough as a good 'allround' diff that has never caused me ANY grief!
Old Apr 1, 2010 | 10:38 PM
boothy's Avatar
boothy
Sounds good karlos must get 1 but they aint cheap
Old Apr 1, 2010 | 10:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i landed a good deal really, got mine in a rebuilt box that suposedly had done only 1000miles for £400!
Although I can't be 100% on that because I did ask the guy if it was a later BC box with the bigger bearings and he said yes... turned out it was a MK3 box which obviously has the smaller bearings, and the clutch release arm had been welded on which wasnt mentioned either!
But, the Quaife was there and the box itself is lovely and tight so I cant complain really, gears are a bit long like a Diesel box as it has a Fiesta final drive IIRC!
Old Apr 2, 2010 | 07:15 AM
JesseT's Avatar
JesseT
The clutch release arm is welded on all mk3 gearboxes. It's the fork that is removable, whereas in a mk4 the fork is welded and the arm removable.
Old Apr 2, 2010 | 08:36 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Ah thanks JesseT I thought it was a bodge! lol
Old Apr 2, 2010 | 10:42 AM
morph's Avatar
morph
how did tell it was a quaife diff without pulling apart?
Old Apr 2, 2010 | 10:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
You can see by looking in the driveshaft holes, looks totally different to a stock diff!
Those 4 cut outs are the biggest give away
Old Apr 3, 2010 | 11:57 AM
muz's Avatar
muz
Wye Valley Hardcore
I haven't used my ATB yet on the road. Really want to compaire what the ATB drives like in comparrison to the brand new Ford LSD my old box had. Just watch you dont hit a bump and lift a wheel mid corner as they need both wheels in contact with the road to work.
Old Apr 3, 2010 | 12:05 PM
Danster76's Avatar
Danster76
Looks like this in situ.
Old Apr 3, 2010 | 12:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Old Apr 3, 2010 | 12:47 PM
morph's Avatar
morph
cheers!
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
mark r
Sep 29, 2015 07:27 PM
`spotty
Sep 25, 2015 11:41 PM
Flatlinedan
Sep 18, 2015 12:41 PM
