Braided brakeline fittings.
Old Mar 30, 2010 | 09:20 PM
Dan track ka's Avatar
Dan track ka
Default Braided brakeline fittings.
I have completed all the track ka in braided hose and euroquip fittings (M10 size) which is all well and good.
However, with the 300mm discs and larger piston callipers i have got a sportka master cylinder and larger servo but the outlets are M12 thread rather than the 1.3 M10 thread size and i cant find fittings anywhere.
Does anybody know what i need and where from. Banjo's or some kind of reducer piece.
Ive tried rallydesign where i got all my fittings.
Cheers, Dan.
Old Mar 30, 2010 | 09:36 PM
Dan track ka
Ah, just found what it might be. 7/16 fittings will be close to 12mm, so banjo's, banjo bolts and washers?
Old Mar 30, 2010 | 10:16 PM
jon@work's Avatar
jon@work
ThinkAuto
Old Mar 30, 2010 | 10:23 PM
pdfbt40's Avatar
pdfbt40
No, they are almost definately M12x1. Sounds as you have a non-ABS master cylinder which would a pressure limiting valves screwed into it for the rear brakes.
Also try www.speedflow.co.uk , very helpful for all types of funny adaptors.
Or even www.pirtek.co.uk if you can get through all the industrial stuff.
Martin
Old Mar 31, 2010 | 06:14 PM
Dan track ka
It used to be linked up to an ABS system but i have removed it and just piped it straight up. Ill check those sites out and see if i see owt.
Cheers, Dan.
Old Apr 1, 2010 | 05:36 AM
JesseT's Avatar
JesseT
Let me know if you find something. I'm in the need of some 12x1 fittings as well for a cosworth master cylinder.
Old Apr 1, 2010 | 08:48 AM
pdfbt40's Avatar
pdfbt40
Silly me
IIRC when I looked at this problem, the most appropriate M12 fittings were for 1/4" pipe, not 3/16".
What I didn't do was look at Ford supplies.
They list male nuts for 4.75mm (3/16") pipe in 'standard' M10 and M12.
M10 - 6758611
M12 - 6758609
Sorry, my hacked Microcat doesn't give prices, but even Fraud couldn't charge more than a fiver each...
Martin
PS. Just been picking up parts for the w/e. Quoted for 6758609 - £2.15 +vat each.
